12-26-2013, 09:15 PM   #1
Does Pentax make the sensor for K3?
12-26-2013, 09:22 PM   #2
crewl1's Avatar
QuoteOriginally posted by Ilovemypentax Quote
No, Pentax does not make any of their sensors. I believe it is a Sony in the K-3.
12-26-2013, 09:26 PM   #3
bobmaxja's Avatar
Canon , Sony and Samsumg make their sensor but it's not an avantage anymore.
12-26-2013, 09:56 PM   #4
I think it is the Toshiba sensor used in the Sony and Nikon
12-27-2013, 01:39 AM   #5
The K-3 has a Sony sensor.
12-27-2013, 01:54 AM   #6
There were many talks everywhere and most concluded it's Sony in K3 :-)
12-27-2013, 03:02 AM   #7
QuoteOriginally posted by bobmaxja Quote
Canon's sensors were always great, and still are. I still consider them as an advantage over others, although advantage not as significant as it used to be.
A decade ago, when everyone was using "colourful" CCDs in their cameras of all sorts and "precise" CMOSes only in their top of the range devices, Canon was installing their marvellous CMOSes even in their entry level SLRs. This was a huge advantage over others IMO. Today everyone seems to use CMOS everywhere, SONY sensors became really good and the difference between "Canon and the world" in sensors' universe is not that obvious anymore
12-27-2013, 03:34 AM   #8
Sony sensors are currently better.
12-27-2013, 04:04 AM   #9
QuoteOriginally posted by Dariusz Quote
I think it would be easier to check dxomark.com for camera sensors rating. Canon sensors are not winners today
12-27-2013, 04:29 AM   #10
Otis Memorial Pentaxian
clackers's Avatar
QuoteOriginally posted by aquashankar Quote
??? Sony put a Toshiba in their Sony ???
12-27-2013, 04:49 AM   #11
When it is a 3rd party sensor, is it made to Pentax specs or is it a standard Sony (or whoever made it) drop in sensor?
Doesn't Nikon make its own sensors?
12-27-2013, 05:14 AM   #12
Sorry, my bad. I was thinking of Sony while typing that. I remembered reading somewhere (cannot confirm) that it was a Toshiba sensor same as one of the Nikon's.
Regarding Canon sensors, I used an SMC Takumar on a Canon 1100D and compared the image to my K100D Super. The Pentax image was better rendered. Again, this is subjective. But Canon does make excellent sensors on their higher end cameras.
12-27-2013, 05:53 AM   #13
Sony provide Pentax with their standard CMOS matrix, i.e. they do not perform its R&D per Pentax specs. However the sensor sandwich (matrix + AA/color filter) is made by Sony at its factories according to the Pentax requirements. Last K-5/3 Pentax cameras use Pentax home developed primary color filter.
12-27-2013, 05:56 AM   #14
rbefly's Avatar
Uh, Nope
Hello Dariusz,
That sounds suspiciously like something you read on a Canon forum. Unfortunately, practically nobody in the world of independent testing agrees, including DxOMark. In fact, Canon-made sensors are often cited as the weakest part of their cameras, not nearly equal to the best Sonys. I've even seen posts from Canon users asking the maker to switch to Sonys for exactly that reason.
And the reason most cameras now use CMOS sensors is because they are much cheaper to manufacture, require less expensive machining for production and use substantially less battery power for image-capturing. Which is probably why Canon initially used them for their entry level cameras.
You might want to Google 'CMOS and CCD Sensors' and click on a couple of links.
Ron
12-27-2013, 11:41 AM   #15
QuoteOriginally posted by rbefly Quote
Hi Ron and thanks for your reply.
There is some inconsistency though. Let me take as an example neutral here make of Nikon. In 2006 Nikon was using CCDs across the whole of its range of cameras. Except one - the top of the range, the most expensive D2Xs. It used CMOS. Were they using CMOS because they wanted to save bucks on the most extravagant model of their whole range? I'm not convinced.
dslr, k-3, k3, pentax, pentax k-3, sensor
What will make you buy the K3? Rupert Pentax K-3 & K-3 II 106 10-19-2013 01:16 PM
Does Pentax make the most weatherproof Cameras? and lenses coreyhkh Pentax DSLR Discussion 24 07-11-2012 08:48 PM
Comparing FF to APS-C: What difference does the bigger sensor make? dosdan Photography Articles 26 07-29-2011 02:53 PM
Does Sigma make the 50 1.4 for Pentax anymore? justtakingpics Pentax SLR Lens Discussion 3 05-18-2011 03:09 AM
Does your sensor make a grinding noise? Gilzuma Pentax K-r 9 03-29-2011 05:51 PM
All times are GMT -7. The time now is 02:21 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
