12-29-2013, 02:43 AM   #1
Mirror lock up
I would like information about the K3's Mirror Up (MUP) shooting mode.
I understand the operation and benefit of mirror lockup.
However, can someone describe how the MUP shooting mode would be used in preference to the 2 second (or 3 second remote) delay mode?
Coming from a K10D, this is one aspect of the K3 I haven't quite understood.
12-29-2013, 02:57 AM   #2
Fogel70's Avatar
One advantage of mirror lock up is that you can lock up the mirror in advance, so you don't have to wait for 2 sec for the shot to be captured.
But it will require a cable release or remote.
12-29-2013, 02:57 AM   #3
dcBear78's Avatar
Most obvious thing to me is when you are unsure of when you want to activate the shutter and can't have the delay. For example waiting for fireworks.
12-29-2013, 02:59 AM   #4
I use MLU during astrophotography sessions when I need to ensure that all vibrations have damped down before opening the shutter. This may or may not be longer than 3 seconds depending on in situ conditions. In this case, I use the shutter setting where first press locks up the mirror, 2nd press opens the shutter and 3rd press closes it.
Jack
12-29-2013, 03:09 AM   #5
Thanks all. Makes more sense now!
QuoteOriginally posted by jbinpg Quote
Jack, what settings do you use for this?
Cheers, Paul
12-29-2013, 12:48 PM   #6
Hi, Paul. Here are my settings for astro work:
1) In shutter settings (up arrow on 4-way controller), I set it to MUP + IR controller.
2) In C-1, option 7, I set Bulb Mode options to Mode 2.
Note that mirror and shutter are on separate drive assemblies in the K-3 so the first press of the IR release will lock up the mirror using these settings.
Jack
12-29-2013, 03:40 PM   #7
Thanks!
dslr, k-3, k3, mirror, mode, mup, pentax k-3
Mirror Lock-up Wingincamera Pentax K-5 4 06-28-2013 03:26 PM
Time lapse shooting with mirror lock-up? jpyykonen Pentax DSLR Discussion 7 01-31-2013 09:26 AM
Mirror lock-up gorski Pentax K-30 & K-50 3 07-23-2012 04:04 PM
K10D mirror lock-up DanLoc78 Pentax DSLR Discussion 2 08-04-2009 09:45 AM
mirror lock up Gooshin Pentax DSLR Discussion 7 03-11-2009 09:02 AM
All times are GMT -7. The time now is 10:51 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
