01-10-2014, 06:18 AM   #1
Newbie question
Can you put a lens with stabilization onto a K3? Can the two systems work together?
Thanks.
01-10-2014, 06:44 AM   #2
You can put an optical stabilized lens on the camera, but only one system should be enabled at any one time.
The reason is that each - the lens system and the in body system has their own sensors detecting movement. If both are enabled, then the lens is going to correct for the movement as the light passes through and then when the "corrected" light hits the sensor, the body will adjust the position of the sensor again for the detected movement - thus "uncorrecting" the light. So, no - having two corrections in series does not work.
01-10-2014, 07:12 AM   #3
tabl10s's Avatar
It's the optical version of "Friendly Fire".
01-10-2014, 07:32 AM   #4
I understand. Thanks for the replies.
dslr, k-3, k3, pentax k-3
newbie question about lighting and white balance rgcote Troubleshooting and Beginner Help 11 10-26-2013 09:22 AM
Newbie question about 2 macro lenses meigloo Pentax SLR Lens Discussion 19 06-11-2013 06:12 AM
Another newbie question about flash on the K-01 Esposizione Pentax K-01 3 04-27-2013 08:08 AM
Newbie Question on Lenses planewood1 Pentax SLR Lens Discussion 6 11-28-2012 02:59 PM
Newbie Question 2 - Auto ISOs Sage97 Troubleshooting and Beginner Help 23 05-02-2012 07:11 PM
All times are GMT -7. The time now is 10:42 PM. | See also: NikonForums.com, part of our network of photo forums!
