01-10-2014, 10:07 PM   #1
K-3 in camera HDR (Dynamic Range)
I wanted to check out te K-3's dynamic range and alignment settings. Firstly, I must say that the alignment of the 3 exposures taken seemed perfect. I can't find any ghosting in the frame on the three handheld shots I did. I think it is terrific. The question I have is that the menu allows for 1 of 3 HDR settings, #1, #2, #3 (duh). However I can't find any reference as to what parameter(s) I am controlling. The results look very close to each other and spotting a difference is difficult. However, there is some variety in the resulting histograms. Can anyone supply an answer?
01-10-2014, 10:11 PM   #2
QuoteOriginally posted by Iam1of2 Quote
The higher the number, the stronger the HDR effect. The camera will overexpose the bright shot more and underexpose the dark shot more before combining the images.
Note that the K-3 supports RAW HDR files, which are huge (80-100Mb) but give you a LOT of control. It's worth checking out!
01-10-2014, 10:20 PM   #3
Thanks for the quick reply. With my k-20D, I shot almost exclusively .PEF files and would do so again if I could find a converter for post work. I use Elements and the Topaz suite which seems to be quite sufficient for my needs. The Adobe converters won't work with my version of the software, (except the new DNG release). Has anyone got experience with a package called "Meta Raw"?
01-12-2014, 12:29 PM - 1 Like   #4
How one should handle K-3's RAW HDR files? Do I understand correctly that the only way is converting a combined RAW HDR file into 3 ordinary raw files? If it so then it is not that advantageos to the usual way of making HDRs from 3 single raw files as it was before.
alignment, camera hdr, dslr, dynamic range, hdr, k-3, k-3 in camera, k3, pentax k-3, range, settings
K-30 dynamic range loco Pentax K-30 & K-50 41 08-27-2012 12:21 PM
I feel the dynamic range in video from k-5 is very limited liukaitc Video and Pentax HDSLRs 4 12-29-2011 07:00 AM
The Pentax K-7: The era of in-camera High Dynamic Range Imaging has arrived! HermanLee Pentax News and Rumors 2 05-20-2009 10:40 PM
HDR (High Dynamic Range) krs Pentax DSLR Discussion 29 01-09-2009 08:48 PM
K10D dynamic range...ISO100, single exposure HDR d.bradley Pentax DSLR Discussion 15 02-10-2008 06:11 PM
All times are GMT -7. The time now is 08:47 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
