01-12-2014, 04:26 AM   #1
Lurch's Avatar
K-3 AF.C questions
Evening guys,
The photoshoot i did yesterday with the bikes was good practice for my panning (although I still need A LOT of work).
I had the camera set to AF.C and 9-point focus. Is this right? Is there something I missed?
(Given that the Sigma 70-300 is not the most accurate/fastest AF lens)
While I'm at it; I'm sure I had my K-5 configured to AF *only* on the rear AF button, with AF disabled on the half-shutter. But I'm stuffed if I can find where to disable AF on the shutter on the K-3. Help?
Never mind - got it. RTFM. Disabling shutter focus is on setting the AF button to 'AF2'
01-12-2014, 09:40 AM   #2
I change between spot focus and 27 point with center selected. Hold on medium. In some situations where the contrast is low and there are a bunch of things close to the same focus distance the extended af gets a bit confused. I have user settings to switch quickly.
01-12-2014, 08:19 PM   #3
Lurch's Avatar
Hold on medium?
01-16-2014, 04:35 AM   #4
dosdan's Avatar
QuoteOriginally posted by Lurch Quote
Hold on medium?
Menu C3 Item #17
Hold AF Status: Medium
Dan.
01-16-2014, 03:03 PM   #5
Lurch's Avatar
QuoteOriginally posted by dosdan Quote
Menu C3 Item #17
Dan.
Gotchya - thanks mate
01-16-2014, 11:11 PM   #6
Trying to learn how to use the K-3’s Focus Tracking for BIF, I practised on cars using the following settings.
SETUP AS USER 3
EXPOSURE MODE - TAv
SHUTTER SPEED - 1000s
f STOP - F4
AUTO ISO RANGE - 100-6400
SHAKE REDUCTION - OFF
CONTINUOUS SHOOTING - MEDIUM
FOCUS AREA – SELECT CENTRE SPOT 9 POINT(PINK)
16-3 FIRST FRAME = FOCUS PRIORITY
17-1 AFA CONTINIUS SHOOTING FOCUS PRIORITY
18-4 HOLD AF STATUS - OFF
You can see the results here.
K-3 Focus Tracking at F8 - a set on Flickr
K-3 Focus Tracking at F4 - a set on Flickr
Has anyone run a similar test and what were your findings.
Greg
01-17-2014, 11:56 PM   #7
I was shooting hawks this week with the DA*300 and found spot focus was necessary. They were mostly against the ground or hills in the background, and the closest was about 50 yards. I had to pan precisely, but managed to get some nice shots. Everything happened very fast, and being so far away the subject was small in the viewfinder. I use Tv and let the iso float with the lens wide open.
If things are closer in the extended points works well. But the body needs something to bite on, and small subjects in the distance don't give it enough to work with.
I need a longer lens.
02-01-2014, 11:53 AM   #8
Menu C3 Item #17
Dan.
It's actually #18 ~ Hold AF Status ~ Medium
02-05-2015, 05:22 PM   #9
Evening guys,
That's fine, but if it's grayed out... then what?
02-05-2015, 08:43 PM   #10
audiobomber's Avatar
QuoteOriginally posted by gregmoll Quote
SETUP AS USER 3
EXPOSURE MODE - TAv
f STOP - F4
Greg
I've shot hundreds of BIF images. My settings are very similar to the above. Here are the differences:
f/5.6 with the DA*300mm, f8 if I'm using the TC, f8 with the 55-300 (good DOF, maximum sharpness in each case)
Continuous shooting max (8fps)
Center point, 27-point expansion (I did use 9-point for vehicles but it's too hard to keep birds in the frame)
Hold AF status, Low - produced the most hits with BIF
I add 0.5EV and fine tune in post
Let us know how your shoot goes.
af, af.c, dslr, k-3, k-3 af.c, k3, pentax k-3
K-3's AF.C with Focus priority. skyer Pentax K-3 & K-3 II 18 12-11-2014 05:44 PM
How good is the K-3's AF-C tracking AF? Jeff Charles Pentax K-3 & K-3 II 6 12-09-2013 03:41 PM
Any news on the K-3 and AF-C with face detection for video? Clinton Pentax K-3 & K-3 II 21 11-09-2013 04:30 PM
K-3 AF-C Test Picts Winder Pentax K-3 & K-3 II 64 11-05-2013 11:09 PM
K-5 AF.S / AF.C / MF switch defective? DSK5 Pentax K-5 & K-5 II 7 04-06-2012 05:05 PM
All times are GMT -7. The time now is 11:58 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
