01-15-2014, 01:18 PM   #16
boriscleto's Avatar
QuoteOriginally posted by SkipperRi Quote
Hm, just now I go online and check what lens is available on local Pentax store. Strange, but there is PH-RBA available, and that's lens that doesn't fit on DA L WR lens, according to Pentax staff. So, I'm confused now. Which hood is for which lens....
Also, that PH-RBA is cheaper, that's make no sense to me. Maybe Jimmy is right, maybe the right hood for my new lens is PH-RBC?
Apparently the database here is wrong. The DA L WR uses the PH-RBC just like the DA.
01-15-2014, 01:29 PM   #17
SkipperRi's Avatar
QuoteOriginally posted by boriscleto Quote
I'm lost. Which hood is the right one for my new lens...
01-15-2014, 01:56 PM   #18
manacho2005's Avatar
The hoods for the original DA's and DA L's had the same bayonet style hood. I never owned a WR kit (other than 18-135), so the bayonet may be different.
As far as the new DA L WR, I don't have a clue. That's why I had said you may need a 52mm screw on hood. I hope someone else knows if the DA WR's have the same mount as the new DA L WR's....
01-15-2014, 02:02 PM   #19
boriscleto's Avatar
If it is a WR (DA or DA L) lens then the correct hood is PH-RBC.
01-15-2014, 02:09 PM   #20
JimmyDranox's Avatar
God knows, ...I try to find that DA L 18-55 WR in Ricoh - Pentax site. There is none.
Lenses - RICOH IMAGING UK LTD.
01-15-2014, 02:33 PM   #21
boriscleto's Avatar
QuoteOriginally posted by JimmyDranox Quote
Because it is a kit lens that is not sold separately by Ricoh.
01-16-2014, 02:12 AM   #22
SkipperRi's Avatar
Thank you, so I must find that hood somewhere...
Regards
01-16-2014, 03:00 AM   #23
PH-RBC is on the first Ebay link that I show yesterday.
01-16-2014, 03:18 AM   #24
rbefly's Avatar
Options?
Hello Skipper,
If you're still having trouble finding the correct lens hood, how about a rubber collapsible type? I believe all the 18-55mm's use a 52mm filter, right?
52mm Rubber Lens Hood for Standard Wide Tele Focus | eBay
Now, if you absolutely have to use the OEM petal-type hood, you can keep looking, but for $5.00, this will do the job just as well. Just retract it for W/A and pop it forward for normal FL and tele.
Just an idea for you, good luck!
Ron
01-16-2014, 03:41 AM   #25
SkipperRi's Avatar
Yes, Jimmy, thank you.
QuoteOriginally posted by rbefly Quote
Hello Skipper,
Ron
Interesting idea. No, it's not necessary tha hood must be petal OEM, thanks for advice.
01-16-2014, 04:30 AM   #26
It could be necessary for wide angle at 18mm a petal shape.
01-16-2014, 07:13 AM   #27
SkipperRi's Avatar
Oh, yes, Jimmy, you're probably right.
01-16-2014, 12:06 PM   #28
PH-RBC should the one; check out this link on the Ricoh site - PENTAX - smc PENTAX DA 18-55mm F3.5-5.6 AL WR
01-16-2014, 12:11 PM   #29
SkipperRi's Avatar
QuoteOriginally posted by agchang Quote
Thanks, that's probably it. Only difference is that mine lens is DA L and have the tiny red line instead green, but construction is same.
01-16-2014, 12:47 PM   #30
Most probably, PH-RBC is the one you need. But if you are not sure, you can buy both, because PH-RBA is under 3,60 euro, and sell the one you don't need.
dslr, hood, iso, k-3, k3, pentax, pentax k-3
Pentax K-3 vs K-30 on AF & high ISO samuelyuen3 Pentax K-3 8 12-05-2013 10:13 PM
ISO limited to 160, not 80 in expanded. toooldtocare Pentax K-5 9 07-02-2013 12:03 PM
ISO range - expanded? ducdao Pentax K-r 14 12-06-2011 10:44 AM
What does expanded ISO really mean for Pentax? Clinton Pentax DSLR Discussion 28 09-20-2010 12:42 AM
iso expanded for k-x? LosHollyBeach Troubleshooting and Beginner Help 7 03-05-2010 09:33 AM
All times are GMT -7. The time now is 08:11 AM. | See also: NikonForums.com, part of our network of photo forums!
