01-29-2014, 10:45 AM   #31
SkipperRi's Avatar
Just to confirm, the hood for this lens is PH-RBC 52mm. I just received original one from local Pentax store, and fit perfectly. In case that someone else has any doubts about hood, the problem is solved.
Thank you all for the suggestions and help.
Regards.
01-30-2014, 06:51 PM   #32
QuoteOriginally posted by JimmyDranox Quote
It could be necessary for wide angle at 18mm a petal shape.
It is necessary to be petal. I had used a rubber screw-on hood on my DA L 18-55; even when the rubber is collapsed I can see heavy vignette at 18mm.
dslr, hood, iso, k-3, k3, pentax, pentax k-3
Pentax K-3 vs K-30 on AF & high ISO samuelyuen3 Pentax K-3 8 12-05-2013 10:13 PM
ISO limited to 160, not 80 in expanded. toooldtocare Pentax K-5 9 07-02-2013 12:03 PM
ISO range - expanded? ducdao Pentax K-r 14 12-06-2011 10:44 AM
What does expanded ISO really mean for Pentax? Clinton Pentax DSLR Discussion 28 09-20-2010 12:42 AM
iso expanded for k-x? LosHollyBeach Troubleshooting and Beginner Help 7 03-05-2010 09:33 AM
All times are GMT -7. The time now is 04:57 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
