01-23-2014, 01:11 PM   #1
No more separate AF option for Live View only?
I have my K-5 set up to perform AF when I press the shutter button half way down.
But when I use Live View, I don't like it that it hunts for focus every time I press down the shutter button to take another shot - so I've disabled AF via shutter button and use the separate AF button instead for it:
Menu -> #5 -> Buttom Customization -> Shutter Button Half Press -> Off (Live View only)
Now I have the K-3 in my hands and can't seem to enable that same mode again. Where we used to have two separate settings for the AF button and the shutter button, there is only one now, and that works for both View Finder and Live modes, it seems to me, as there is no setting for the "Shutter Button Half Press" any more.
So, does someone know how I set a K-3 to perform AF via the shutter button only in View Finder mode but not in LV? Or is has Ricoh frecked this up?
01-23-2014, 01:39 PM   #2
unkipunki's Avatar
QuoteOriginally posted by tempelorg Quote
I don't think that's possible with the K3. What is really noticeable though is that the Live View AF with the K3 is much more responsive and finds lock a lot faster than it did with either the K5 or K5iis
01-23-2014, 01:59 PM   #3
Set the AF button to 'AF2' in the 'button customize' menu. This will disable the shutter button half-press AF.
(p.74 of the K-3 manual)
01-23-2014, 02:12 PM   #4
unkipunki's Avatar
QuoteOriginally posted by Steve.Ledger Quote
That disables the half press for both normal and live view. The OP was looking for one that only disables the half press for Live View. Which I don't think is possible on the K3.
01-23-2014, 02:21 PM   #5
p.46 of the manual
Any help?
01-23-2014, 02:34 PM   #6
jup
I don't think you can do it. I use AF2 (back button autofocus) only, but as was mentioned before, that influences both live view AND viewfinder.
As a workaround, you can use user mode. Create one with setting that you normally use for live view, like back button autofocus and possibly others. AF button customization is part of what gets saved in user mode too.
01-23-2014, 03:09 PM   #7
@jup, your suggestion sounds reasonable as a work-around. I had not expected that button customization would be saved separately per user mode, so I wouldn't have even considered this option without your help.
@Steve.Ledger - thanks for trying twice, but both don't help - I guess I didn't explain my issue well enough.
af, af option, button, dslr, finder, half, k-3, k3, pentax k-3, press, shutter, shutter button half press, view
Preset options like in Pentax K-30 has ceased to be K-3 Ztrejfer Pentax K-3 13 12-08-2013 03:46 AM
Pentax K-3 vs K-30 on AF & high ISO samuelyuen3 Pentax K-3 8 12-05-2013 10:13 PM
Size of K-3 center AF point vs. K-5? twitch Pentax K-3 23 11-17-2013 10:14 PM
K-5 ii vs K-5 iis comparison with higher sharpness in K-5 ii kataria0 Pentax K-5 62 12-22-2012 10:12 PM
First AF test K-5 vs K-5IIs ogl Pentax K-5 8 11-01-2012 05:46 PM
All times are GMT -7. The time now is 01:36 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
