Originally posted by grispie As Kadjawi stated, i think the flatter the image is, the easier it is for the camera to process it.
Also notice how the shadows and highlights are well preserved.
Now you can pump up contrast, sharpness and the 'overall image' again in post. your pc & software is much more powerful at that than your camera.
But it is the same story here: i learnt by making mistakes that you have to do things the right way...
Yes. Pumped up contrast and especially detail require much more bits than a flat picture, so reducing artificial detail (which can be added later if necessary) makes a lot of sense when the encoder runs out of bits.
@PiDicus Rex: I was merely the one who expressed the hope that there was something like Lightroom in terms of controls for video correction and grading... only to be told that Lightroom can do that.
I'll have to try that with some videos that really have the wrong white balance... sometimes I get along with Filmconvert and Colorista, but sometimes I fail utterly.
I haven't even heard of Edius. Will have a look
Yes, Resolve gets lots of mentions, and there is a free version. Haven't installed it yet.
Virtualdub has a great noise reduction plugin called Camcorder Color Denoise Filter, it works like the color denoiser in Lightroom and does a great job at removing that ugly color noise and turning it into beautiful grain (sort of). Use it moderately, cause quickly smooths out the red channel, otherwise though it works well.
If you're fine with scripts you can also use AviSynth... for interlaced material I use QTGMC, does a great job at deinterlacing (and it perfectly doubles the frame rate, so 50i video turns into 50p). I have not seen any deinterlacer that comes close to this, in all situations and is as reliable.
I think when shooting with the K-01, and to a lesser degree with the K-3, framing for the codec/encoder is important. You'll want to avoid detail, especially when in motion. Otherwise the inefficient encoder that doesn't have enough space anyway will have to throw out a lot of data just to make it fit into the confined space it gets. So lots of rippled, moving water is a big no-no.
Btw., I have received more footage from the Panasonic HC-X900 (around $1500?), shot at 50i with a bitrate of 12 Mbps (!). The camera can do much better than that. But after deinterlacing it looks pretty decent, there is plenty of detail and you have to look closely to see it fall apart. You don't see blocking even in detailed scenes. The encoder is pretty good I must say. The rest of the camera except for the great optical stabilizer (though it looks artificial...) pretty much sucks though. Skin tones look awful, you can constantly see the sensor clipping, even if it's only for one color channel, there is plenty of aliasing and moire, ...
Maybe I'll find 2 similar shots, one from my K-5 and one from the Panasonic camcorder, and post screenshots. For those who say "use a camcorder if you want to shoot video! Get rid of video in DSLRs!".
