@jhmos: Oh, thank you! That's a nice find.
Someone needs to tell Pentax that we can work around the noise easily (and it really was not a problem on the K-5 in pretty much every single shot. Unless the mechanism has become much louder or the microphone much more sensitive. I barely, if at all, hear it in my shots), and that the reduced battery life... I've shot about an hour of video AND taken somewhere around 1200 photos on ONE battery. SR was always on. One of the BlackMagic Design cameras can last 20 minutes on a battery.
I think the Pentax lasts long enough.
I think the video anti aliasing is not so important. The next generation of Fujitsu processor and Sony or Toshiba will probably offer full sensor readout and downsampling, and then moire and aliasing should be much less of an issue.
@PiDicus Rex: Sounds good. Premiere Pro doesn't support 10 bit h264 files, the decoder will read them as 8 bit files, meaning the colors will go wrong etc.
That cross... it can make sense, depending on the story, though personally I think the slider and length was a bit much. Could be a horror film... Anyway, if you want it to be jarring, leave it there. If not... maybe another place.
@grispie: I've given it a go too. I also edited them a bit, normally I don't have anything with narrative to play with. Since I didn't know where you were going with the story I just went with a nice, warm look. First some sharpening, then Filmconvert emulating some Fujifilm stock (I've used the D7000 profile) and a bit 3 way color correction to give it some warmer mids and teal-ish shadows. The noise that Filmconvert adds (at 50%) do mean that bitrates explode a bit. I'm getting somewhere around 24 Mbps.
The files look good to me. I liked grading them. However upon closer inspection, especially after grading, some bad blocking becomes rather apparent when there is movement of smooth surfaces. As in when her face moves through the frame for example (not the hair). Look at it frame by frame. It should not happen during scenes this noise and detail free. I decided to look at the Sony alpha 57 footage too, and yes, it also has these problems. My K-5 files, and their transcoded variant using the same h264 codec (but a different, more sophisticated encoder) at much lower bitrates do not show these artifacts. I have the feeling that at least this generation of built in h264 encoders is not without flaws.
https://drive.google.com/file/d/0B26uSljVPN-NODJhdHl3UHJ3eHM/edit?usp=sharing
You can download the original file. It is much better looking. All the grain for example is completely gone in the preview, even at 1080.
