01-31-2014, 02:05 PM   #1
K3 video formats and DVD
If I understand correctly the K3 video format uses a .MOV container for a format of MPEG-4 AVC/H.264 which I believe should capable of producing HD videos on DVD using a suitable Video Editor software. I would be indebted if anyone could verify my statement and possibly suggest what would be a suitable codec to produce the HD DVD.
01-31-2014, 08:12 PM   #2
You're not going to have any trouble using the footage from the camera for DVD authoring.
The program you use to create and write the DVD .vob files will handle it well enough.
VOB - Wikipedia, the free encyclopedia
02-01-2014, 06:23 AM   #3
CDW
I think the OP wants to burn an HD file on DVD media to play back on a Bluray player. Perhaps Boxcam can confirm and whether or not he's using a Mac or a PC. Some video editing programs and disc burning software don't support burning AVCHD files to DVD media.
02-01-2014, 09:14 AM   #4
Hi CDW - Many thanks for reply. You have got it absolutely correct, that is what I want to do. I am using a a Pc with Windows 7 and using Serif MoviePlus X5 for video editing. I was really asking if the K3 video files were good enough to produce HD movies on DVD. You seem to imply that they would be OK.
02-02-2014, 06:42 AM   #5
CDW
Doing a bit of search, it appears your software can export an AVCHD file. I found it less clear that you can burn that file directly from the software to a DVD. In my situation, using a MAC, I export AVCHD files to a Movies folder, then use ROXIO Toast to burn them to DVDs. I have found the AVCHD files, in direct comparisons of the same material, to not match in quality, the same material exported and burned as a Bluray file on a BDR media. But the AVCHD files are a quantum leap in quality beyond standard definition video burned to DVD.
02-02-2014, 08:43 AM   #6
Many thanks once again CDW for the extra informatiom. I wiil bear this in mind for future reference, but for now I will have to stick with AVCHD to DVD as I have just ordered a Blu Ray Player and it will be a little while before I can afford the expense of a Blu Ray burner.
02-02-2014, 08:49 AM   #7
schnitzer79's Avatar
Best software ive used is vso convertxtodvd.lets u customize ur own menu, add comments and can easily convert any video file to dvd format. Another good one is dvdfab
02-02-2014, 01:01 PM   #8
QuoteOriginally posted by boxcam78 Quote
They're only $75-100...
dslr, dvd, format, hd, k-3, k3, k3 video formats, pentax k-3, video
K3 Video Issue - low audio level? Sleepy Pentax K-3 22 01-13-2014 06:35 AM
Test video K3 grispie Video and Pentax HDSLRs 52 01-10-2014 08:41 AM
K3 Video - Two questions boxcam78 Pentax K-3 4 11-14-2013 07:34 PM
K3 Focus Peaking During Video? DDoram Pentax K-3 18 11-09-2013 10:31 PM
New k3 YouTube video bobell69 Pentax K-3 11 10-12-2013 05:56 AM
All times are GMT -7. The time now is 07:57 PM. | See also: NikonForums.com, part of our network of photo forums!
