01-31-2014, 06:04 PM   #16
VisualDarkness's Avatar
What drive mode are you in? Remote or similar greys it out.
01-31-2014, 06:56 PM   #17
MJSfoto1956's Avatar
my drive mode as advised by many is "M".
Unless you are talking about something else...
m
01-31-2014, 07:02 PM   #18
manacho2005's Avatar
The mode dial needs to be on M to properly meter, but the drive mode is the shutter's setting (ie single shot, self timer, mirror lock...) The drive mode needs to be on anything but self timer or mirror lock. Check this by pressing "up" on the Dpad.
01-31-2014, 07:07 PM   #19
drive mode is continuous shooting high. (I always use back button auto focusing + continuous with all my cameras)
and changing it to single mode doesn't change anything.
I'm stumped!
m
01-31-2014, 07:12 PM   #20
QuoteOriginally posted by MJSfoto1956 Quote
m
That is the program/shooting modes. Drive mode is the different types of shooting (eg Hi-speed, mirror lockup, remote etc).
01-31-2014, 07:12 PM - 1 Like   #21
Do you have "Using Aperture Ring" set as permitted in your settings?
01-31-2014, 07:13 PM   #22
Can you shoot at all?
01-31-2014, 07:22 PM   #23
oh it shoots very well! Exposures are spot on. I'm impressed at how good it is.
The only issue is that the SR doesn't work (as stated, both SR and set focal length settings are greyed out in the menus), which was a primary reason I purchased a camera system with vibration control in the body: i.e. to work with legacy lenses.
Did they change things between K-5 and K-3 ??
M
01-31-2014, 07:26 PM   #24
QuoteOriginally posted by manacho2005 Quote
BINGO!
Thanks so much!
Michael
01-31-2014, 07:35 PM   #25
So you could shoot with the adapted lens despite having Aperture ring permitted set to off?
01-31-2014, 07:49 PM   #26
yes. I was impressed that the exposures were spot on in various lighting.
Note that I'm used to Nikon's way of doing things.
But the way Pentax integrates with legacy glass kinda makes sense now.
Clearly they have done some clever engineering to make it seamlessly (although the "Use Aperture Ring: Yes | No" takes some pondering to understand all the implications).
M
01-31-2014, 08:24 PM   #27
BINGO!
Whew! This one had me on my toes...
Glad it worked out!
01-31-2014, 11:12 PM   #28
The one item that I wish Pentax would change on their default setup is to have "use aperture ring" enabled. It makes no difference when using any of the auto aperture lenses, and you only set it once when you get a new body. But, it creates problems such as this when its not set.
01-31-2014, 11:28 PM   #29
I'm not really sure why you would ever need to toggle this option off.
01-31-2014, 11:54 PM   #30
wizofoz's Avatar
Agreed. Why is it even an option? It should just be enabled and left that way. I know no reason to turn it off.
dslr, k-3, k3, length, lens, pentax k-3
Using "Input Focal Length" with A and M Lenses ENicolas Pentax K-5 7 11-03-2012 09:01 AM
Ned Bunnell: " I assure you Ricoh has clear plans to revitalize the Pentax brand" Unsinkable II Pentax News and Rumors 96 10-07-2012 08:03 AM
Where to get start when it comes to learning "the how" jtkratzer Troubleshooting and Beginner Help 44 07-22-2012 04:43 PM
"input focal length" on af lens...yeah. synonyms Pentax K-5 3 10-27-2011 08:16 AM
which focal length(s) are considered "fish eye"? slip Pentax SLR Lens Discussion 3 12-13-2006 10:51 AM
All times are GMT -7. The time now is 12:44 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
