Originally posted by kosmoejtg I didn't realize that ISO could be so different between manufacturers. I read a thread earlier bashing DXO, I guess they do serve a purpose if they expose this like this.
I'm one who's been critical of DXO. But they definitely serve a purpose.
The problem's more that some people quote them as an absolute authority, rather than simply using them as a resource which does useful, but limited testing.
Obviously, their results need to be applied properly. Their data should be used to predict, or perhaps explain, the results we'll get when using the equipment. And their "actual ISO" measurements can help make sure we're comparing apples to apples. But their numbers can't replace the actual results we get using the equipment.
The problem with both numbers and observation (quantitative and qualitative) is that they both require understanding the context - you have to pay close attention.
The pitfall with numbers is that they're prone to the illusion that they're easy and absolutely reliable. We can forget that they're still completely dependent on the test conditions, sample variations, and most importantly the fact that the tester has to think of all possible relevant variables, along with ways to deal with them. In some cases he may not be able to measure or adjust for certain variables - even if he's fortunate enough to identify them in the first place.
