02-02-2014, 07:34 AM   #1
K-3 incorrectly reports battery grip battery dead
Received a new K-3 and battery grip last week - the B&H deal.
I have eneloops in the grip (6 AA batteries) that are charged, and the pentax battery in the K-3.
In the menu setup I had 'auto' selected for battery type, and 'grip first' selected regarding the preference of which power source to drain first. After taking just a couple of shots, one with flash, the camera reported "battery depleted" and lockup up (white lettering on a black background on the rear LCD.
I turned it off, waited a few minutes and turned it back on. Then I went back into the menu and selected "auto" for the power source preference (grip vs camera). The camera reported that both power sources were at full charge.
I will try to choose Ni-Mh as these batteries run at a slightly lower voltage than alkaline AA's, and will retry the 'grip first' setting. There seem to be two implications of the above:
1) the 'auto' battery selection does not correctly recognize the nominal voltage characteristics of the envelop batteries and
2) the "auto" setting for the power source does not allow the system to automatically switch from grip to camera when the grip batteries become depleted.
I don't yet yet know if the auto setting will support a switch from camera to grip when the camera battery is depleted, nor what the behavior will be with the grip first, or camera first settings.
Interested in the experience of others on the forum.
02-02-2014, 09:34 AM   #2
Na Horuk's Avatar
Hey there. Are you using the latest camera firmware?
02-02-2014, 12:58 PM   #3
Indeed - downloaded and updated to 1.01.
02-02-2014, 01:01 PM   #4
QuoteOriginally posted by tram57 Quote
A slight correction for #2 -- I mis-spoke. Should read:
2) apparently when selecting 'grip first', the camera does not automatically switch to the camera battery when the grip batteries are depleted or reported to be depleted.
02-02-2014, 02:13 PM   #5
It has been my experience that AUTO selection of battery will only be triggered if the camera is turned off and on.
Jack
02-02-2014, 02:50 PM   #6
interesting -- what is the behavior if "grip first" is selected, and the grip runs out of juice?
02-04-2014, 02:13 PM   #7
As far as I understand the new 1.02 firmware has fixed this bug.
02-04-2014, 10:03 PM   #8
Do you mean 1.01? No it doesn't. My grip batteries, (NmH) depleted today and it shut the camera down. I put a new regular battery in and it started up. I'm going to auto now to see what it does. Doesn't it make sense to have the grip deplete first since it is the easiest to change out rather than taking off the grip to get to the camera battery? What are others finding on their grip batteries? This may be only a AA battery issue.
02-04-2014, 10:14 PM   #9
dosdan's Avatar
QuoteOriginally posted by gosman Quote
Do you mean 1.01?
No, try 1.02: Latest K-3 Firmware Update : Software Downloads | RICOH IMAGING
Changes to V1.02
  • Added Bracket shooting in [Anti-Aliasing Filter Simulator].*How to operate Bracket shooting click here.
  • Improved stability for general performance. *Contents of [Version 1.01] will be also updated and following contents will be improved.
  • Improved stability of battery level indicator when using with battery grip.
  • Optimized performance of continuous shooting when setting AF.C mode.
Dan.
02-05-2014, 07:17 AM   #10
Thanks Dan- this must be a brand new firmware? I just updated to 1.01 two days ago!! Impressive that Pentax is acting this quickly with firmware updates.
02-05-2014, 11:57 AM   #11
This was what I had originally noticed. The behavior of my K-5 was that there would be automatic switching from grip to camera battery when the grip becamse depleted. The K-3 both mis-reported that the grip battery was dead when it was not (with the battery selection set to auto, and NiMh batteries in the grip), and failed to automatically switch from the grip to the camera battery when it reported that the grip batteries were depleted.
I saw another post suggesting that the v1.02 firmward has not remedied this problem? Will be interesting to see what folks report with v1.02.
02-05-2014, 12:06 PM   #12
SkipperRi's Avatar
Strange, I'm not suffered that problem with 1.01 firmware, maybe because in my K-3 are both Ni-Mh batteries.
02-05-2014, 12:58 PM   #13
jpzk's Avatar
Does the firmware 1.02 resolves this issue: https://www.pentaxforums.com/forums/172-pentax-k-3/242792-k-3-power-issue.html ?
JP
02-05-2014, 01:19 PM   #14
No, this issue is not fixed.
02-05-2014, 01:28 PM   #15
jpzk's Avatar
QuoteOriginally posted by jpzk Quote
QuoteOriginally posted by Grokh Quote
Too bad.
One has to wonder if this will ever be fixed with firmware or perhaps it is an entirely "physical" problem.
JP
batteries, battery, battery grip, battery grip battery, camera, dslr, grip, k-3, k3, pentax k-3, power, power source selection, reports battery grip, source, switch
battery grip for K-3 fialdj Pentax K-3 3 04-06-2014 06:27 AM
Day bag for k-3 with battery grip? alwaysmichellerene Pentax K-3 22 02-12-2014 01:37 AM
Pentax K-5 D-BG4 Battery Grip on a K-3, really possible? pentaxmz Pentax K-3 8 12-02-2013 05:55 PM
For Sale - Sold: Pentax D-BG4 Battery Grip for Pentax K-7 & K-5 with Battery djrocks66 Sold Items 4 08-11-2013 08:10 AM
For Sale - Sold: Pentax D-BG4 Battery Grip for K-5 / K-7 w/D-Li90 battery Adam Sold Items 3 05-31-2013 01:05 PM
All times are GMT -7. The time now is 07:20 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
