02-05-2014, 09:14 AM   #31
dbh
Just an FYI - the file I got (and installed last night) from the Russian site yesterday is byte-for-byte identical to the one I downloaded from the Japanese site this morning.
02-05-2014, 09:34 AM   #32
Upgrade certainly is giving me more accurate readings on my battery grip. We will see if it successfully transfers power to battery in camera.
02-05-2014, 09:54 AM   #33
sundr's Avatar
QuoteOriginally posted by dbh Quote
When I saw the news early this morning, I figured I was wrong about my beta test speculation (teaches me to keep my empty-headed speculations to myself).
I did the upgade this morning. everything works. Though it took me two tries.. For some reason with the first try when I would turn the camera on while pressing menu, I did not get the upgrade screen. did this repeatedly but would not work. I finally reformatted the disc and re-downloaded the firmware. It worked! whew
02-05-2014, 10:12 AM   #34
PALADIN85020's Avatar
I just downloaded v.1.02 and installed it in the camera. Everything went smoothly.
I WILL BE INTERESTED TO KNOW IF ANYONE STILL EXPERIENCES "MIRROR FLUTTER" WITH THIS FIRMWARE VERSION. I've only had it happen once with v. 1.01, but that was once too often.
John
02-05-2014, 10:16 AM   #35
MJSfoto1956's Avatar
download + install went smoothly, no hiccups. I will test later.
M
02-05-2014, 10:36 AM   #36
Tjompen1968's Avatar
One can just love Pentax for introducing new features and this fast since releasing the camera.
02-05-2014, 11:41 AM   #37
Can someone confirm whether this update improves the number if keepers while focus tracking is enabled?
If true that would be great news for action sports shooters.
02-05-2014, 12:46 PM   #38
GoremanX's Avatar
QuoteOriginally posted by gosman Quote
Broke? How did that happen?
Who knows? Card came out, card won't go back in. When I tried to push it in, it got jammed and had to be yanked out with pliers. Mechanism appears to have broken.
02-05-2014, 12:49 PM   #39
crewl1's Avatar
Although there is no mention of it - is there any improvement to the flash delay issue with this FW?
02-05-2014, 12:57 PM   #40
QuoteOriginally posted by crewl1 Quote
No significantly improvement.
02-05-2014, 12:59 PM   #41
jup
QuoteOriginally posted by Grokh Quote
Yeah, seems the same delay is still there.
02-05-2014, 01:01 PM   #42
jpzk's Avatar
And how about this problem: https://www.pentaxforums.com/forums/172-pentax-k-3/242792-k-3-power-issue.html ... ?
Does FW 1.02 fix it ?
JP
02-05-2014, 01:01 PM   #43
crewl1's Avatar
QuoteOriginally posted by jup Quote
Thanks, bummer
02-05-2014, 01:03 PM   #44
QuoteOriginally posted by jpzk Quote
JP
Not also. Still the same situation.
02-05-2014, 02:28 PM   #45
NicoleC's Avatar
The update went off without a hitch for me.
batteries, battery, broken, camera, cards, devices, dslr, fingers, firmware, firmware 1.02, grip, k-3, k3, lens, menu, pc, pentax, pentax k-3, root, sd, selection, switch, thousands, times, upgrade
K-30 Firmware Update v. 1.03 bluenose Pentax K-30 & K-50 4 03-18-2013 09:07 AM
New FIrmware Update v.1.12 geru2000 Pentax K-r 53 06-07-2012 11:30 AM
K-x Firmware 1.02 dragra Pentax DSLR Discussion 44 05-02-2011 10:14 PM
New Firmware Officially Posted (1.02 K-5, 1.01 K-r and 645D) nixcamic Pentax News and Rumors 9 01-05-2011 08:47 PM
K100D firmware V 1.02 Bostjan Pentax DSLR Discussion 4 05-21-2007 12:57 AM
All times are GMT -7. The time now is 04:40 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
