02-08-2014, 11:18 AM   #1
Eye cup for K-3
Has anyone found an eyecup that fits on the K-3 yet? I wear glasses. Most I have found of course are for Nikon and Cannon.
02-08-2014, 11:58 AM   #2
brosen's Avatar
I am using the Pentax M 30086 eyecup, works really well, check this thread
https://www.pentaxforums.com/forums/172-pentax-k-3/246194-pentax-k-3-pentax-e...ml#post2622429
02-08-2014, 12:08 PM   #3
The K-3 eyepiece is the same dimension as the M-series film cameras and all subsequent Pentax SLR bodies. It should accept a wide range of accessories from Pentax and many other makers.
02-08-2014, 12:12 PM   #4
Brosen, see my comment question on your thread.
---------- Post added 02-08-14 at 01:19 PM ----------
Has anyone tried this one:
Vello ESP-DSLR Eyeshade for Select Pentax Cameras ESP-DSLR B&H
02-08-2014, 12:34 PM   #5
brosen's Avatar
QuoteOriginally posted by gosman Quote
In the B&H website description says "Select Pentax SLR and DSLR cameras; replaces FL, FP, FR, FN, FO eyeshades" and the K-3 User Manual describes the Eyecup as FS, I do not know, they might not be compatible
02-08-2014, 02:33 PM   #6
QuoteOriginally posted by brosen Quote
It is my understanding that the only difference between the stock eyecup for the K-3 (FS) and that for the K-5 (FR) is that the K-3 version does not have the cut-out for the diopter adjust. Accessories such as Vello unit should work since it has a ton of clearance and should not interfere with the K-3's diopter dial.
02-08-2014, 04:17 PM   #7
Canada_Rockies's Avatar
There is also the option of the O-ME53 magnifying finder which helps with manual focus lenses.
02-08-2014, 05:16 PM   #8
unkipunki's Avatar
I took a punt on the currently unavailable Esung SEAGULL Multifunction Camera Eyecup Set for Canon/PENTAX/NIKIN/OLYMPUS (Black) and found the eyecup useless due to being overly rigid and not fitting the curvature of my glasses. However it did come with a set of camera manufacturer specific spacers, most of which I threw away along with the rubber eyecup. I kept the Pentax spacer and remounted the standard K3 eyecup with it. The standard K3 eyecup curves slightly when fitted to the spacer and I find that this nicely moulds to my glasses and steps the eyecup away from the screen. This hasn't completely eradicated greasy screen syndrome, but it is much improved.
02-08-2014, 05:22 PM   #9
This will fit
If you look closely, the picture on the B&H website clearly shows it mounted on a Pentax DSLR -- it actually shows the Pentax name on the rear LCD. Probably a K-30. Also, the spec says it will replace the "FL" eyepiece, which is exactly what came on the *istDS.
Stevebrot pointed out that everything since the M-series film cameras will fit, and he is always right. I can vouch that my rubber eyecup, my "FL" eyepiece, and my O-ME53 are completely interchangeable between my ME, *istDS, and K-5.
Maybe after you buy it, you can come back to this thread and post your impressions.
02-08-2014, 06:08 PM   #10
Too late. I bought the round one through another thread via Amazon by way of Japan! And you are right- I just looked at my old istDS. Same one as the K-3. Time for Ricoh to change to a more professional eye cup.
dslr, eye cup, k-3, k3, pentax k-3
Sports K-3 and 60-250 do college football finals : Vanier Cup bdery Post Your Photos! 6 10-30-2014 06:16 AM
Larger eye cup for K-30 or similar model? Newtophotos Pentax DSLR Discussion 4 12-20-2013 10:48 AM
Eye cup magnifiers marquis1955 Troubleshooting and Beginner Help 6 07-11-2013 06:02 PM
Wanted - Acquired: Rubber eye cup for Pentax KX (not k-x) Franky2step Sold Items 1 04-15-2012 08:21 PM
Eye cup for ME Super gregmacc Pentax Film SLR Discussion 13 08-29-2011 02:08 PM
All times are GMT -7. The time now is 11:46 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
