Originally posted by IchabodCrane Built-in GPS?
Yes, that and WiFi.
If we're not going down the FF route, a different type of crop sensor. Like a Foveon or X-Trans . . . possibly. Something with much less noise at much higher ISO. Also with more dynamic range as we've slipped a wee bit in this department, not that I've really noticed a difference over the K-5IIs.
More focus points spread further across the sensor. Let's make the rule of thirds easier without the need to crop. AF and tracking AF to be class leading, only in the Nikon D4 class I mean.
Even more buffer capacity and the ability to optimize use the ultra fast cards (200mbps+).
An ability to project focus peaking through the viewfinder so you can use focus peaking without having to use Live View. Dunno if this is even possible?
No more mirror flops and battery issues. My K-3 still refuses to switch on about 10% of the time requiring battery removal to fix.
Make the selector knob (M, TAv, Av etc) out of metal or much better grade of plastic.
Better USB ports. I can't get the cable into the micro-USB port anymore on the K-3. Dunno what happened there? Also a better door on the ports than just a bit of rubber. Also try to get it down to one or two ports for charging and communication link.
Usual evolution of screen resolution above 9XX,XXX whatever dots.
Remove the pop-up flash. I know many like the pop-up flash but I'd prefer Pentax remove this and offer a smaller hotshoe flash at reasonable value. I have no idea why I want this but I wrote it anyway.
More than halve the physical size of the D-Li90 battery without losing capacity and include two battery slots in the body. [I'm just making this stuff up now whatever pops into the head]
