03-16-2014, 03:58 AM   #46
JimmyDranox's Avatar
I think that you can try to install the upgrade again. Maybe was a problem when you installed it, and the second time will work fine.
Anyway, I don't know if an downgrade is possible, but I always keep the updates, 01, 02, etc, in my computer memory, just in case.
By afraid, I don't have older upgrade files for K-3, because I don't have a K-3. But maybe someone has, and can send you one.
03-16-2014, 08:07 PM   #47
Thanks for the reply Jimmy, I will give that a try and see what hoppens, hereis hoping that that works.
---------- Post added 17-03-14 at 03:56 AM ----------
QuoteOriginally posted by JimmyDranox Quote
Hi Jimmy reloaded the update seems to be okay so far need to take out on a trip but at the moment am house bound, thanks for he info will keep that in mind for if a do another update.
05-06-2014, 08:32 PM   #48
I'm getting ready to install Firmware 1.03 how do I format my sd card . I got a 32 g with my camera I took a few pictures and I deleted the file thats had the photos on it so it looks blank . How do I know if its formated or not. I found something about format on page 31 in the manual. It doesn't say anything about having to do this step when updating firmware . after I did the format in the camera I put the sd card in the computer and it now shows us as a external drive and is names k-3 so I guess I did it .
05-06-2014, 08:55 PM   #49
Hit the menu button, use the arrows to go to the Tool 4 menu, and you will see Format.
06-20-2014, 02:12 AM   #50
PT1
Only updated to 1.01 so far. Was looking for 1.02 (maybe 1.03 is too new?) and found previous versions are still downloadable:
http://www.ricoh-imaging.co.jp/english/support/digital/firmware/k3_101.EXE
http://www.ricoh-imaging.co.jp/english/support/digital/firmware/k3_102.EXE
-- there's no 1.04 there yet :-)
06-20-2014, 02:35 AM   #51
Tjompen1968's Avatar
No need to update all of them in sequence. Just grab the latest.
06-21-2014, 08:13 AM   #52
PT1
Yes, I only looked for 1.02 because I hadn't downloaded it, and had seen a couple of mentions of 1.03 freezing. But decided to use 1.03 after I'd read the release notes.
The 1.03 self extractor gave a weird message about not installing correctly, so I ended up downloading the .zip file instead.
battery, camera, count, dslr, fault, firmware, focus, grip, jimmy, k-3, k3, lens, pentax k-3, reason, sandisk, shutter, slot, thanks, try, update, upgrade
K-5iis 1.03 Firmware stability (or lack of it) RobG Pentax K-5 14 02-23-2014 02:44 AM
Problems extracting firmware 1.03 on Mac reasonosx Pentax K-01 7 04-02-2013 04:57 PM
K-30 Firmware Update v. 1.03 bluenose Pentax K-30 & K-50 4 03-18-2013 09:07 AM
K-5 IIs firmware 1.03 improves tilt flash overexposure issue bjdavey Pentax K-5 11 03-11-2013 10:42 AM
K20D firmware 1.03 - doesnt use SB for the 540 and 360 flash? 247nino Pentax DSLR Discussion 10 07-28-2009 04:35 PM
All times are GMT -7. The time now is 02:38 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
