Originally posted by AquaDome The hole-puncher double-sider turns a 180k floppy into a 360k floppy.
Very good (although I was kinda wondering if the op knew) - we have a winner! It let's you flip it over and use the second side, which has maybe a 70-80% chance of being as reliable as the first side (since the second side was presumably never tested for QC).
But let's face it, I'm right and you're wrong on the SD card issue!
In any case, neither have I had a problem while using the factory format on my (mostly SanDisk) cards. I'm more comfortable with it, because sometimes I'll do
crazy things like only deleting some of my photos, or deleting some from the camera and others from the computer. If it matters which device you format the card on (and it appears to), then by formatting on a certain device you've just made the card more compatible (or reliable) on that device. A factory format on a good card seems to work well on almost all devices out of the box (and any devices it didn't work well on would be suspect).
