03-15-2014, 08:32 AM - 1 Like   #16
Oldbayrunner's Avatar
QuoteOriginally posted by Belushi Quote
As you can read in my post here
https://www.pentaxforums.com/forums/120-general-technical-troubleshooting/253...not-found.html
it was exactly vice versa for my K-500!
Card used: Older 1GB Transcend
Formatting the SD-card in the cam: Update not recognized (as if not there)
Formatting the SD-card with my cardreader under WinXP ("FAT", no quick-format, volume label "K-500"): Worked like a charm!
Yes, strange, I know. But Ricoh did not reply to my support request and so I just gave it a try.
Maybe there was a firmware bug in V1.0 (K-500) that did not allow updating the firmware?? Don't know.
But NOT formatting the card in the cam was the solution for me!
Since you decided to quote me, I didn't say it wouldn't work I said it was not recommended. Use of the OS format eventually may cause problems using your card with your camera. SD Formatter is specifically designed to do either quick or low level formats on SD cards to clean up the sectors and mark any bad ones without harm. Using SD Formatter and the cameras formatter, unlike the OS format, does not destroy the partition that is initially created and read by the camera. The camera creates that partition to keep initial files it needs unloading and reloading within one area of the card and not be scattered throughout the card. Once that partition is destroyed those files are allowed to scatter all over the card as the camera's processor does not read and put everything back on the card in a nice neat order. What eventually happens is over a period of time ones camera will start reading the card slower looking for files it needs, or not be able to read them and one gets the dreaded card read error or format card error. BTW continued use of delete over a period of time can cause the same errors due to build up of portions of data that it does not remove from sectors within the card and which the cameras formatting doesn't remove either. This can be corrected once it happens by doing a low level format on the SD card. So I suggest keeping that 1GB card to do your updates but I recommend not using the OS formatting for your cards you use for your photos.
If you would like to use the SD formatter in the future here is the link;
https://www.sdcard.org/downloads/formatter_4/
camera, card, dslr, firmware, firmware update, k-3, k3, pc, pentax k-3, time
Catch In Focus ... can't get it to work ? zman Photographic Technique 28 04-09-2014 03:16 AM
can't get to the pentax site!! Katmandude Pentax DSLR Discussion 8 12-06-2013 09:30 PM
Question Can't find the links page (trying to get a link to Eric's services) ismaelg Site Suggestions and Help 3 12-02-2010 01:15 PM
Can't seem to get RA3 to work..?? arbib Digital Processing, Software, and Printing 4 11-01-2009 06:40 PM
Don't update to the 1.01 firmware! It breaks autofocus jms698 Pentax DSLR Discussion 45 10-01-2008 01:22 PM
All times are GMT -7. The time now is 04:02 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
