03-09-2014, 03:03 AM   #1
NicoleC's Avatar
A tale of two cards
I was up early, so I decided to start processing my photos from yesterday before heading out again today. I pulled the main card and to my horror, no pictures. None. No client, but I had a couple of really nice shots I wanted. I checked my camera settings, and there were indeed card 1 -> card 2 for overflow.
Wait, I had thumbnails and checked images yesterday! The main card had been switched to "lock" somehow. I grabbed card 2 and indeed all the photos were there.
Given the K3 won't work if there is not card in slot 1, I was pleasantly surprised that it was smart enough to roll over to the other card if it the first one was locked. *whew!*
03-09-2014, 03:09 AM   #2
Tjompen1968's Avatar
QuoteOriginally posted by NicoleC Quote
You say that the K-3 does not work without a card in slot 1. Mine does...
03-09-2014, 06:59 AM   #3
NicoleC's Avatar
Maybe they fixed that in a firmware update. i haven't tried it in a while.
03-09-2014, 07:10 AM   #4
Given the K3 won't work if there is not card in slot 1...
Like noted before, you may wish to explore this observation further.
Once () I forgot to return my card to slot one (1/DNG --> 2/JPG). The camera had no problem carrying on with my card in slot 2 (2/DNG+JPG). It was a "" moment when discovered. Anyway, no problem.
Cheers... M
03-09-2014, 09:59 AM   #5
Dark Underlord
AquaDome's Avatar
I have done the same: forgot to replace the card in slot 1 and found my photos on the card in slot 2.
While shooting in HS-C, the K-3 has, on occasion, written a stream of photos to card 2 instead of card 1.
I assume this is an I/O feature to keep things moving while the buffer empties.
If I hadn't eventually filled the first card, I might not have ever checked the second.
Then I would have made a troll-post blaming the camera for my "missing masterpieces".
03-09-2014, 12:02 PM   #6
Eyewanders's Avatar
QuoteOriginally posted by AquaDome Quote
I've encountered this as well. (And just confirmed that mine does indeed work fine if there is a card only in slot-2). For these reasons I've actually started connecting the cam via the USB3 port so that both cards show up on my laptop and I can just import all at once, or at least one right after another. (Plus it's wicked fast) There's definitely an organizational and mental "heads-up" that needs to happen simply having 2 slot options now.
03-09-2014, 03:38 PM   #7
NicoleC's Avatar
Mine shoots fine with no card in slot 1 now. First thing I did was verify is was set to overflow to slot 2 and left it there, so either they fixed it or mine hiccuped when I first got it. I wasn't used to having two slots and left my #1 card in my computer the next time I took it out. At the time I thought it was dumb programming but was thrilled to have a back-up card slot when my memory fails. (As it seems to do so often.)
card, dslr, k-3, k3, pentax k-3, photos, yesterday
Landscape Tale of two cities Dice Post Your Photos! 3 01-02-2014 08:10 AM
A tale of two cameras, K-r & MZ-7, and three lenses manstanox Troubleshooting and Beginner Help 3 03-12-2013 03:24 AM
A tale of two cameras (D800E vs 1D4) Christine Tham Non-Pentax Cameras: Canon, Nikon, etc. 15 05-21-2012 03:02 AM
A Tale Of Two Systems brumby Pentax DSLR Discussion 54 04-26-2009 10:34 AM
All times are GMT -7. The time now is 03:18 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
