03-11-2014, 02:01 PM   #1
Manual lenses with K3?
Has anyone used a manual lenses with the K3?
If so please let me know the basics for the setting up the camera to accept the manual lens.
I have switched the camera over to manual, but the shutter will not depress and no pictures are taken.
Thank you for you help.
03-11-2014, 02:07 PM   #2
wtlwdwgn's Avatar
If the aperture ring does not have an 'A' (auto) position you need to go into menu C4, No. 27, and set 'Use aperture ring' to yes. Page 83 in the K-3 manual.
03-11-2014, 02:10 PM   #3
jatrax's Avatar
This might help: https://www.pentaxforums.com/forums/58-pentax-beginners-corner-q/110658-using...x-dslrs-f.html
Not sure if it has been updated for the k-3 but outside of the menu setting noted above everything else should be the same.
03-11-2014, 02:16 PM   #4
QuoteOriginally posted by wtlwdwgn Quote
Thank you for your quick response to my question. I will give it a try today after work.
---------- Post added 03-11-14 at 01:19 PM ----------
Great information I know that this will help.
03-11-2014, 04:24 PM   #5
Using Manual lenses on the K-3 is the same as the others. Make sure you have aperture ring use enabled on the camera, select the focal length, set your ring to the intended aperture, then use the green button for stop down metering.
03-11-2014, 04:44 PM   #6
Parry's Avatar
M42's manual primes are the only lenses that get used on my K3 now.
03-11-2014, 07:07 PM   #7
QuoteOriginally posted by Parry Quote
Which ones??
03-11-2014, 07:52 PM   #8
I got my K3 to put on my Taks. What a pleasure to use now. Results I could not dream of with the older body.
03-12-2014, 02:54 AM   #9
clackers's Avatar
Why would you restrict yourself, Parry?
12-11-2014, 06:24 PM   #10
I think there are a few of us doing the same.......We love the old glass !
Its for a reason.....
aperture, camera, dslr, k-3, k3, lenses, manual lenses on k3, menu, pentax k-3
Manual Metering on Pentax DSLRs with Manual and Automatic Lenses Adam Pentax DSLR and Camera Articles 20 01-06-2016 03:38 AM
Post Pictures of your Silver K3 with Black Lenses? haziz Pentax K-3 4 11-15-2013 04:37 PM
Preparing for the K3 with great lenses ? jpzk Pentax K-3 4 11-12-2013 03:27 PM
Manual lenses with K5ii sofiab66 Pentax K-5 5 03-22-2013 10:19 AM
Movies with manual lenses? Rob22315 Pentax K-01 4 03-05-2013 06:29 PM
All times are GMT -7. The time now is 04:07 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
