05-13-2014, 07:41 PM   #226
K10DK7's Avatar
I was doing a shoot on Sunday using a K3 SE, so it had original Pentax batteries. Lens was a Sigma 100-300mm EX. Av mode at 100 ISO. It burst into the mirror flap mode and although I immediately switched of at the power switch, like others have stated, it did not stop the rattle. I then quickly started to undo the grip in an effort to remove the battery in the body. It stopped flapping and upon re-attaching the grip and switching on, continued to work fine for the rest of the day.
No idea what the cause was. It was the second event I've had with the K3. The first was just a total freeze up that needed the grip and camera battery removed.
Love the camera but not happy with issues like this.
Come on Ricoh, let's have this issue resolved please.
Camera serial No. 2573653
Best regards
05-15-2014, 06:52 AM   #227
Finally I received the K3 fixed. It had failed after a Mirror Flapping Lockup and did not power on again.
I sent it for warranty repair on 3rd March, from Italy to France. Returned today 15th May. It really has been too long.
See attached the repair report. It seems they replaced several parts: main circuit, flash circuit and "deffective assembly", whatever it means.
I surely would have been a happier custumer by getting a full camera replacement instead, in much shorter time. But the camera is back, and that is good. No mirror flapping seen so far.
IPhone 4S  Photo
05-15-2014, 08:52 AM   #228
First week with the K-3
I have encounter the runaway mirror syndrome. This is my first week with the K-3 Premium Silver Edition. The temp was 45F at 79% relative humidity. Firmware updated to 1.03. Both the K-3 and battery grip had the batteries loaded and turned on. The camera was programed in interval movie record mode at 2 sec intervals in full HD with live view. Photos were taken for about 20 min before the mirror flapping began. Turning the off switch stopped it after a few seconds. The gear used in the camera set up was new Pentax branded equipment except for a SanDisk card in slot #1
2 x Pentax Li-Ion battery D-LI90
Pentax OFC-1 16GB FluCard for Pentax K3
SanDisk 8GB SDHC memory card
HD PENTAX DA 55-300mm f/4-5.8 ED WR
05-16-2014, 06:47 AM   #229
QuoteOriginally posted by fcrespo Quote
Crossing fingers for you the 'fix' fixed it.
The K-3 was in repair limbo for nearly 2 and 1/2 months. Completely unacceptable. Continuing to watch this thread out of amazement of Ricoh's failure to address the Pentax K-3 customers. There may never be a K-4 if this keeps up.
05-17-2014, 11:04 PM   #230
After 1st incident in beginning of april (as I reported here), yesterday my k-3 went in machine gun mode again. About 30 minutes before a lot of pictures were taken.
The original Pentax battery was nearly empty. After removing it for some seconds everything was ok.
I didn't replace the low battery, but there was no more mirror flapping for the rest of the day.
05-18-2014, 10:40 AM   #231
Interesting here to note that some of the forum members try to declare this (in my opinion serious) lack of reliability into the corner of "random" issues and triviality. This seems to be a typical trait of Ricoh/Pentax and there hardcore believers. I consider such attitude at least as questionable.
05-18-2014, 12:18 PM - 1 Like   #232
QuoteOriginally posted by WaveDancer Quote
I see you've met the human race.
You will see that in forums for all brands among the hard core believers.
05-18-2014, 02:43 PM - 1 Like   #233
Without any real data as to the scope of the problem, it is all but impossible to say whether this is truly a "serious" problem or not. Of course, if it happens to you, it is serious, at least to you.
Just how big is this "serious problem" anyway? 100% of all cameras sold? .1%? .01%?, .001%? There is no way to know. Do you even own a K3 or even any Pentax camera? if not, why even bother to make this comment, other than trolling that is?
It is just a camera, not life and death.
It comes with a warranty,
If it fails, send it in and get it repaired or replaced just like you would if your car breaks down or your dishwasher stops working.
Otherwise if you cannot deal with possible failure, buy another brand (like Nikon, which never has problems I hear ), or never buy anything because of fear that it might break.
Ray
05-18-2014, 11:09 PM   #234
karro's Avatar
Perhaps, I'm one of "there[sic!] hardcore believers", but, eh.. I support Ray's take on the situation.
If this is a "vote or die" question for you - there are numerous brands out there, that [apparently] provide much more reliable gear. Use them; when I bought my K-3 (with the issue, mind you), no one forced me to sign in blood "never to touch other camera again, or else!"
It isn't a car. One's life is not depending on this, or if it is - trust me, that person has far bigger issues to deal with than a floppy mirror.
I'm not trying to downplay the issue. There is one. What I won't do is mounting a crusade because of it.
05-18-2014, 11:36 PM   #235
Wired's Avatar
Happened to me on Friday. Using latest software and camera had a fresh battery, freshly formatted 32gb sandisc extreme pro and the flu card loaded up. For ten frames and then the camera went shutter crazy. Wouldn't turn back on for about an hour afterward. Disappointing
---------- Post added 05-19-2014 at 12:40 AM ----------
QuoteOriginally posted by Ray Pulley Quote
Ray
Lol. Agreed. My D800 and AFS 24-70 2.8 have been sent to Nikon three and two. I've never sent in a Pentax unless I did the breaking.
05-19-2014, 10:24 AM - 1 Like   #236
Rupert's Avatar
From some of the replies here....from being an "asset" to being a small irritant.....it appears there is little need for Ricoh to address this "minor inconvenience"? (and so far they haven't!) Is that accurate? I have always expected things I purchase, in particular more expensive items, to operate as intended. Am I somehow out of touch with the new age of consumers?
I've had good results from most of my Pentax gear, excluding faulty SDM lenses, and don't look to knock the products, but I'll be damn if I would make excuses for such a major problem. Just my two cents, I know it wasn't asked for and was probably not welcome, but a little reality might bring some of you back to the real world where people that sell high dollar gear are held accountable, and quickly. If this is the new Ricoh/Pentax, how is it better than the old Hoya/Pentax...other than higher prices?
Regards!
05-19-2014, 11:44 AM   #237
yorik's Avatar
This thread is for people who want to report a problem. Why not leave it (the thread) at that?
Oh wait - you answered my question.
05-19-2014, 01:36 PM   #238
awaldram's Avatar
QuoteOriginally posted by yorik Quote
Report a problem ?
To who do 'they' think there reporting.
I'd be reporting my problem in person to the shop I purchased the faulty goods from ..... As Rupert asks has something changed in the word of consumerism where you rant on a web forum and someone fixes your issue ??
What do you reckon which (200 moans in a web thread or 200 returned cameras ) is going to get a manafacturers interest ?
05-19-2014, 02:08 PM   #239
yorik's Avatar
This thread gives people who have experienced a problem like this a resource - information, suggestions etc. This thread is also collecting data on a fairly large number of episodes which, as I understand it, will be collected and forwarded to Ricoh via one of their representatives to help them figure out how to fix it. Anybody who has experienced this problem can also return it to the store from which it came, and at least some have. But it does no harm to also submit their data to a collective pool.
If you don't like the point of the thread, why do you keep coming back? I don't think that anyone submitting their data here needs to be scolded by you. Surely there is public house somewhere in Hampshire at whose denizens you can rail.
Full disclosure - I only come back to this thread because of the you and the other `scolders'. I don't have a K3. (And there is no decent public house where I live )
05-19-2014, 03:49 PM   #240
Actually, not really. From my experience, they generally direct you to the manufacturer to repair rather than handle anything on their side. Assuming the purchase isn't within the standard 30 day period anyway.
Though I'm still shocked as to why there are so many down players all around. It's almost as if there's a magical world in some people's mind where if you sit by quietly and act good Ricoh will pat you on the head and reward you.
adapter, batteries, battery, body, camera, conclusion, crazy-ass mirror sickness, dslr, frame, grip, issue, k-3, k3, kiss, mirror, mirror sickness mirror, pentax, pentax k-3, post, shots, sickness, temperature, time, time lapse, view, voltage
K-3 failure - couldn't stop the mirror flapping up and down Photodana Pentax K-3 26 06-11-2014 03:19 PM
Help - Pentax K2 Mirror Lockup replacement barbosas Pentax Film SLR Discussion 6 11-06-2013 08:09 AM
Mirror lockup O'Brien 860 Pentax K-30 & K-50 23 07-14-2013 05:16 PM
Pentax MX mirror lockup lever mod? asaru Pentax Film SLR Discussion 4 12-24-2012 07:45 AM
mirror lockup Andrew Crouch Pentax K-5 5 12-13-2012 04:42 AM
All times are GMT -7. The time now is 09:20 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
