03-12-2014, 12:22 PM   #1
Resolved- 645 adapter stuck on k3
Hi everyone,
I was surprised when I could not get the 645 adapter (looks like a generic one) off of my K3. Yes, I am familiar with the ricoh pin issue and tried sliding a metal tape between the mount and adapter - no avail. tried for over 2 hours. Feeling helpless. Maybe I should just take it to a camera shop?
I have sucessfully used this adapter on my k20d with no issues mounting and removing. Anyone know if the mount pins are any different on the K3? Any pointers about removing the adapter is appreciated.
03-12-2014, 04:45 PM   #2
on the plus side...
I like the 120 macro on it. Just a test shot:
[IMG][/IMG]
03-12-2014, 09:31 PM   #3
Canada_Rockies's Avatar
Just a shot in the dark - try removing the adapter with the AF lever on MF to retract the screw drive into the body. I have heard of some adapters getting stuck with the screw drive in a screw hole.
03-13-2014, 02:57 AM   #4
QuoteOriginally posted by Canada_Rockies Quote
Thank you Canada Rockies, I did retract the AF lever. The adapter seems to be stuck somewhere in the 6-9 'O clock position. At times I wonder if the adapter is stuck within the mount ring rather than on the surface of the mount ring (as it happens with the ricoh pin). I plan on taking a break and coming back to it over the weekend. Do not want to damage the camera...
03-13-2014, 08:02 AM   #5
I'm sorry the idea did not work. Good luck with the camera on the weekend.
03-14-2014, 01:07 PM   #6
Resolved
Took the camera to the local camera shop. I knew that there was a Pentax enthusiast there. He came through - he was confident about extricating it and gave a firm pull at the right place (after wiggling a little bit). Will post pictures of adapter later so that others who have the same can be cautious about using it on some SLRs.
Thank you again Canada Rockies for your responses!
03-14-2014, 07:06 PM   #7
You are welcome, but I did not find the answer for you!
645 adapter, adapter, dslr, k mount camera, k-3, k3, mount, pentax k-3
M37 to M42 adapter stuck on lens .a.t. Troubleshooting and Beginner Help 10 07-09-2013 11:32 PM
Mount rotation on 645 to K adapter Vinelander Pentax SLR Lens Discussion 5 12-28-2012 11:01 AM
HELP! Tamron PKA adapter stuck on K5 body Nick Troubleshooting and Beginner Help 16 06-23-2012 11:23 AM
Help really appreciated! - adapter stuck on 24mm/f2.8 lens ... evalon Pentax SLR Lens Discussion 6 05-21-2012 12:30 AM
Pentax 645 stuck on M 1000 (LCD and viewfinder) Smolk Pentax Medium Format 2 08-18-2010 04:23 PM
All times are GMT -7. The time now is 03:12 AM. | See also: NikonForums.com, part of our network of photo forums!
