Originally posted by stevebrot My question as well. The focus mode should not impact P-TTL function since it is not part of the equation. The camera does not need to know focus distance in order to measure the intensity of the pre-flash burst and it is never part of the equation. That is, after all, why we use P-TTL. What is more, the AF system does not calculate actual distance, it merely establishes best focus regardless of distance.
Your underexposure at very close distance is not unexpected depending on what you mean by "close". Most on-camera flash units do not have wide enough coverage to illuminate a subject at closer than about a 18 inches. That is why specialized ring flashes and off-camera flash are the norm for close-up and macro work.
Yeah, I have seen in the EXIF that is merely indicates something like "close" or something like that. I don't know if it does anything more precise internally but at least from the EXIF it seems distance is a pretty rough estimate. Oddly, in some file's EXIF I see "Approximate Focus Distance" with a value of feet. Again, it is a pretty rough measurement as the value is "4" when the camera is definitely closer than four feet. But I cannot figure out how to get the camera to recreate that value in the EXIF so I cannot determine the accuracy.
Regardless, the measurement is probably equally inaccurate. :-(
FYI, segment of EXIF:
Format : image/dng
Creator Tool : PENTAX K-3 Ver. 1.03
Metadata Date : 2014:03:23 18:56:43-04:00
Lens : smc PENTAX-DA* 16-50mm F2.8 ED AL [IF] SDM
Approximate Focus Distance : 4
Date Created : 2014:03:23 18:52:23
Subject Distance Range : Macro
And I understand where you're coming from that the underexposure is not unexpected at close range but the specific cases being argued are handled perfectly with the K5. So it is not a limitation of the flash but a limitation of the camera.
There are certainly problems with determining proper exposure at "normal" flash power when the pre-flash is so close and so relatively bright that the camera sees only pure white due to the solar blast conditions of being extremely close. I'm simply not that close yet.
I guess the question would be, can you think of any argument supporting why the K3 cannot handle this situation that also explains why it works perfectly fine with the K5.
---------- Post added 03-29-14 at 09:59 AM ----------
Originally posted by Class A What exactly do you mean by "manual focus lens"?
Note that unless your lens is at least an "A-lens", (supporting the P/KA mount) P-TTL won't be used at all.
he, he, yeah, the LensBaby is certainly not an 'A' lens so as far as the camera is concerned there isn't even a lens connected at all, and everything becomes fully manual.
