03-26-2014, 06:00 PM   #1
Purple and Green Photos
I have been using my K3 and loving it.. But today I was shooting pictures and they were all purple or green or over exposed no mater what settings I used.. I looked at the WB but all was normal.. I tried removing the battery but nothing worked until I went through the menu and put everything to Default.. which I am pretty sure was actually as I already had it set.. Any ideas on what might have happened? I sure don't want to have it happen again.
I could post a sample photo showing the problem.. but it was not consistent other than all were bad.. mostly it was a green hue but also some were purple..
Many thanks for an opinion... BOB
03-26-2014, 06:09 PM   #2
Man With A Camera
Racer X 69's Avatar
Sample photo?
I think the skin tones are off a bit, maybe a tad overexposed, but otherwise it looks OK.
03-26-2014, 06:49 PM   #3
K David's Avatar
QuoteOriginally posted by Pelham Quote
How were you holding the camera or was it on a strap? My K-7 used to hit my belt buckle and the metal loop would cycle through the color spaces when it bumped. I found that out the third time I came back from shooting and the images' colors changed periodically. So my guess is that maybe something in how you carried it accidentally switched back and forth from normal color to cross process.
03-26-2014, 07:06 PM   #4
manacho2005's Avatar
Sounds like a digital filter set to random.
03-26-2014, 07:35 PM   #5
Otis Memorial Pentaxian
QuoteOriginally posted by Racer X 69 Quote
Sometimes excess exposure is a good thing
Ok...back to the OPs post. Racer's image (above) was made with a K-5. I re-ran the sample photo magic and was unable to find any overwhelming tendency to purple or green. Can you provide a few examples from your shooting? Make sure that the EXIF is intact.
03-26-2014, 08:54 PM   #6
There seem to be at least two issues here: colour, and exposure, so it's not just WB.
What was the lighting? If it was LED lighting, there's your problem.
And were you shooting JPG or DNG? How were you processing the images? If you were using (for example) Capture One to process your DNG's, that could also cause your problems, since C1 currently goes green and purple crazy when rendering K-3 DNG's.
03-26-2014, 10:06 PM   #7
Yes. Oversaturated sections in some software ends up being odd colors.
03-26-2014, 10:59 PM   #8
Digitalis's Avatar
...or if he was taking photos under fluorescent lighting with shutter speeds above 1/60th
03-27-2014, 05:08 AM   #9
QuoteOriginally posted by K David Quote
I was holding the camera by the Pentax strap around my neck.. thus it is possible something got "bumped" giving me some weird settings.. I was outside in bright sun using ISO's from 200 to 800 using my 100mm Pentax macro lens..
I appreciate all the suggestions.. clearly some setting got way off as re-setting to default did cure it.. Just hope it doesn't happen again..
Looks like being careful not to bump buttons is a wise observation...
Many thanks.. BOB
03-27-2014, 02:25 PM   #10
Man With A Camera
Racer X 69's Avatar
Well, it wasn't my image. The OP's post had the words "sample photo" in it, and the forum software created a link to the sample photo section of the forum. I kinda made my post as a wise acre, and do indeed hope it raised a grin or three.
Many thanks.. BOB
It is good that you are back on track and making good pictures again, but it would be nice to know what was causing the issues.
dslr, green photos, k-3, k3, k3 problem, pentax k-3, purple
Purple toned photos Pancolart Pentax Q 13 07-08-2013 09:18 AM
Pentax Red/Green/Purple???? magkelly Pentax DSLR Discussion 13 10-06-2010 08:35 PM
Is this much green and purple fringing normal ? eblis Pentax SLR Lens Discussion 3 06-30-2010 10:55 AM
Purple and green Eastern Shore Charlie Post Your Photos! 4 05-17-2009 05:55 AM
Red and green outlines in photos ADKphoto Pentax DSLR Discussion 9 02-10-2008 07:49 AM
All times are GMT -7. The time now is 10:38 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
