Hi there,
I'm a new user on K3.
On Nikon D90, I can hold two buttons together and the camera resets settings related to taking a picture, to defaults, i.e. drive mode, white balance, etc.
Is there an equivalent on K3?
Based on research, I found out about the following two options:
#1) uncheck items from "Memory" under Menu/Camera4. But the camera forgets stuff on every on/off. During events, I may turn off the camera to save power.
#2) select Reset under Menu/Setting3. This is what I like, but it also resets other settings related to the camera usage - such as screen brightness, volume, etc.
#3) There is also a "reset custom functions" under Menu / Custom4. Not that this does what I want, but I like this reset affects only the customs settings.
I read some people recommended using user memory to achieve this. I tried but it didn't work for me.
I saved defaults settings within P mode to a user memory. If I go from P to U1 and then back to P, camera still remembers what I chose in P mode. Maybe I'm doing it wrong?
I'm now a paranoia because last month I was experimenting with drive mode and left it multi-exposure mode. Then forgot about it. A few weeks later during a party I thought the camera went crazy (after reading the shutter machine gun threads). Luckily I had chosen 2 photos to be averaged together, otherwise I would have the whole party in one image
I love the image quality, the tones and the ergonomics of K3 so I need it to be fool-proof under pressure
thanks,
