Originally posted by twitch From DXO...
Fuji X100: Claimed ISO3200 = Measured 1,012
Pentax K-3: Claimed ISO3200 = Measured 2,933
Olympus EM1: Claimed ISO3200 = Measured 1,900
I think it's useful to read the fine print:
"A manufacturer has two options for increasing ISO sensitivity; either to order the sensor to increase its analog sensitivity, or after a picture is taken to tell the camera to amplify the image signal via algorithms at the
RAW conversion stage.
Fujifilm decided to implement the second choice with the X100 and this processing action is normally invisible to the user.
As long as the algorithms used for the treatment are performing well, there is no real problem for the end user. As far as RAW measurements are concerned, the sensor’s maximum sensitivity is ISO 1000. That’s why none of our metrics goes further."
Hasn't it been proposed by some here that the Sony sensor really only goes to something like ISO 1600 (if that)? Everything past that is just from gaining up the signal. Doesn't seem DXO has tested any Fujifilm sensor in the past three years so we can only speculate the results are the same for later models.
