04-11-2014, 12:00 AM   #16
it seems you don't understand my point of view.
Jpeg sooc is bad in the K3.
It's a evidence.
If your practice is to use RAW, that problem doesn't exist. Point.
IMGP0260 par Blu Horizon,@6400ISO (RAW processing)
04-11-2014, 01:12 AM   #17
Here a good explanation about NR (for Jpeg sooc) issue:
<<One of our observations when using the K-3 is that there wasn't a noticeable difference between JPEGs with noise reduction off and noise reduction set to auto. As unprocessed RAW files contain much more noise than either type of JPEG, we can conclude that the K-3's image engine automatically applies a generous amount of denoising to its files, removing much chroma and luminance noise even with noise reduction turned off.
This makes things easier for the end user, though it also takes away the flexibility of processing noisy JPEGs on one's own.>>
I am comforted by the fact i share the same conclusion that PentaxForums staff!
Read more at: Pentax K-3 Review - Studio Tests -
04-11-2014, 01:23 AM   #18
I don't see a huge visible noise problem with the K-3 below ISO 1250-1600. Noise is there, of course, but it isn't a distraction. How visible a problem is is largely depends on your in-camera JPEG settings, the shooting and lighting conditions, and the type of scene. The level of apparent noise in a well lit daylight scene at ISO 1600 will be lower than that of a dark indoor scene shot at the same ISO.
Aside from the levels of NR you enable in-camera, your sharpening settings can make a big difference too. If you over-sharpen even a well-lit and exposed K-3 (or K-5) ISO 100 image using the in-camera settings or in post-processing, you will see more noise (or 'grain', if you count that as 'noise'), especially in the shadows and the out of focus areas. The in-camera settings for contrast can also play a role in making a JPEG appear noisy.
However I agree that Ricoh needs to continue to improve the JPEG engine on the K-3. I'm still not completely confident that they have it fully optimised yet.
dslr, iso, jpeg, k-3, k3, k3 jpeg sooc, k5, nr, pentax k-3, quality, sooc
Need advice for SOOC settings jon404 Pentax K-5 12 03-12-2014 06:22 AM
Pentax K3 jpeg unknown lens in Aperture Paul the Sunman Pentax K-3 5 01-28-2014 09:43 AM
K3 Jpeg EXIF Data is missing values unkipunki Pentax K-3 9 11-14-2013 03:22 AM
K3 vs K5II Burst Shooting Video(RAW+JPEG) davidreilly3207 Pentax K-3 1 11-11-2013 09:47 PM
Misc SOOC nudes icywarm Photo Critique 4 10-22-2010 07:10 AM
All times are GMT -7. The time now is 09:39 AM. | See also:, part of our network of photo forums!
