04-10-2014, 11:25 AM   #1
Help with my laughable error :)
So I was going camping last weekend and I went to take some night shots. As I went for the shot, my battery died, so in the dark I changed my battery. The camera wouldn't turn on, so I went to take out the battery, and it would not eject. Come morning time I realized I had put the battery in backwards! Now it's stuck, with a bit of wiggle room side to side.
Any suggestions about how to fix this? With spring finally arriving here in Ohio I'd love to take some shots
Thanks I'm advance!
04-10-2014, 11:40 AM   #2
tomwil's Avatar
The following 2 threads might help:
https://www.pentaxforums.com/forums/120-general-technical-troubleshooting/169...tuck-k20d.html
https://www.pentaxforums.com/forums/136-pentax-q/254925-pentax-q10-battery-stuck.html
Is there enough room to get tweezers in there?
04-10-2014, 11:53 AM   #3
Tjompen1968's Avatar
I tried to put it in the wrong way but I could not get it all the way due to the small outcropping in the bottom. Did you force it alot? I think the glue idea is worth a try.
04-10-2014, 12:27 PM   #4
c.a.m's Avatar
Try this:
Make a tab out of strong heavy-duty adhesive tape - something like Gorilla Tape. Afix the tape to the exposed end of the battery and down the sides if there is clearance. Wiggle the battery as you pull up slowly. The battery might come loose before the tape pulls off. Duct tape might also work. Masking tape probably not.
- Craig
04-10-2014, 02:50 PM   #5
QuoteOriginally posted by c.a.m Quote
Try this:
- Craig
My addendum to Craig's suggestion: That Gorilla tape "sets up" into a stronger bond over the course of days. So I'd get down a firm, broad attachment; then wait 2-3 days before attempting the extraction by this method. Of course, there's also the glue approach...
04-10-2014, 04:13 PM   #6
chimpwithagun's Avatar
If you have a hardware store nearby, ask if they have "spring stock", it's basically a thin piece of flat metal. Get the thinnest gage they carry, slide that between the battery and compartment, twist with your wrist (this makes tension between the compartment and battery) and pull. The more you twist, the more tension. This may put a scratch on your battery and compartment if you're not careful, but it won't actually cause any damage.
Make sure you pull slowly - pulling fast WILL gouge the plastic of the battery and the compartment.
You may need to try several times - just pull slow, and try adding different amounts of tension (by twisting your wrist)
If the hardware store does not sell spring stock, you can usually find a spring gauge at hardware or sometimes auto parts stores - you should spend around $2 for spring stock, but spring gauges are around $12
This method works because the edges of the spring stock are pointed, they "dig" into the plastic when you twist your wrist, and since spring stock is wider than tweezers or similar devices, it has the least chance of "gouging" the soft plastic.
04-10-2014, 05:16 PM   #7
MJSfoto1956's Avatar
I highly recommend everyone put an LED headlamp in your travel kit. More often than not it is invaluable.
Michael
04-10-2014, 10:22 PM   #8
QuoteOriginally posted by MJSfoto1956 Quote
Michael
A led lamp is also good for light painting =)
battery, dslr, k-3, k3, laughable error, pentax k-3, shots
Help with repairing my Russian lenses kcobain1992 Pentax SLR Lens Discussion 6 11-23-2013 10:38 AM
Need help with my K-X Randolph Arends Troubleshooting and Beginner Help 7 03-31-2013 07:08 PM
HELP - F-- Error (Blinking) with new SMC Pentax-M 50mm F1.7 IanAntonio Pentax K-5 6 10-18-2012 01:39 PM
Can you help with my lens list? April.H Pentax SLR Lens Discussion 22 10-16-2012 07:49 AM
Question PC - error / issue with Modern Skin. NOT SITE MY PC HELP!! vievetrick Site Suggestions and Help 2 11-06-2008 11:24 AM
All times are GMT -7. The time now is 08:54 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
