04-12-2014, 07:28 AM   #1
AF Fine Adjustment
This morning I was attempting to adjust the AF fine adjustment for the 18-135 WR lens, but no matter which direction or amount of adjustment I made (option 3 so it was just for the particular lens), nothing changed.
Has anyone experienced this? What did you do to make it work (if it ever did)?
04-12-2014, 07:58 AM   #2
manacho2005's Avatar
Try adjusting-->then turning off-->unmount lens-->turn on-->turn off-->mount lens-->check focus. Seems tedious, but I found that to work best.
04-12-2014, 09:13 AM   #3
Unregistered User
Guest
QuoteOriginally posted by sadatoni Quote
Where you in Live View?
04-12-2014, 10:18 AM   #4
QuoteOriginally posted by Tjompen1968 Quote
No. Used the viewfinder.
---------- Post added 04-12-2014 at 10:28 AM ----------
QuoteOriginally posted by manacho2005 Quote
Thanks Matt! That worked.
John
04-13-2014, 07:14 AM   #5
Glad to help!
05-06-2014, 07:21 AM   #6
John
Can anyone tell me why Pentax/Ricoh would NOT fix this in a firmwear update, or do they NOT know it is a problem.
Hope to hear from someone soon.
05-06-2014, 09:01 AM   #7
Otis Memorial Pentaxian
That does seem tedious. I have not had to adjust any of my lenses, but will have to remember this workaround.
05-06-2014, 09:31 AM   #8
Unregistered User
Guest
It works fine with all my lenses. No turning and twisting. A +1 or -1 adj. is visible but if at 18mm it may be hard to see. Also distance and f-stop is factors on how much depth of field you generate, i.e if it is visible.
05-06-2014, 10:19 AM   #9
MJSfoto1956's Avatar
you do NOT need to turn your camera on/off between AF fine tune settings with the K-3. All you need to do is focus at something close to you, then move your camera to the test target using the new setting. Record your result. Change the AF fine tune, Focus again on something close to you. Again move your camera to the test target. Repeat until you have done all the tests. As a side note: I find using a large bird feather at a slight angle to be an excellent target (especially if the feather has a contrasty spot on it).
YMMV
Michael
05-06-2014, 11:59 AM   #10
karro's Avatar
I second Michael. When I was toying around with focus fine adjustments, I focused, took a photo, checked the focus, adjusted, saved, refocused to something close (usually - a hand in front of the lens, it doesn't need to lock the focus, it just needs to change the focus distance significantly), then refocused on the target, took the photo, checked the results, etc.
I used GhettoCAL: A DIY Lens Calibration Tool for Microadjustment-Enabled DSLRs
05-06-2014, 04:19 PM - 1 Like   #11
bxf
bxf's Avatar
Of course for lenses that have Quick Shift, a flick of the focus ring will do the trick even faster.
05-07-2014, 02:11 AM   #12
awaldram's Avatar
Should not 'normally ' be required but I think the offset is stored in the lens rom or at least referenced from it.
So sometime the update is not loaded back and a bit of persuasion to re-read is required .
I never seen this with 'Pentax' DA glass.
adjustment, af, dslr, k-3, k3, lens, pentax k-3
AF Fine Adjustment Settings Gemvision Pentax SLR Lens Discussion 5 02-24-2014 06:50 PM
AF Fine Adjustment for Zoom Lenses RockvilleBob Pentax SLR Lens Discussion 6 12-02-2013 05:46 AM
AF Fine adjustment OrchidJulie Pentax K-r 23 11-05-2012 03:47 PM
AF Fine Adjustment in metadata? robheath Pentax K-5 & K-5 II 4 08-21-2012 03:57 PM
AF Fine Adjustment, focus correction, AF micro adj., AF fine tuning annajonna Pentax K-5 & K-5 II 13 11-19-2011 11:32 PM
All times are GMT -7. The time now is 08:55 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
