04-17-2014, 01:49 AM   #1
U1, u2, u3
Hello Guys,
Can you share what settings did you choose for these 3 positions: U1, U2 and U3?
Thanks!
04-17-2014, 02:53 AM   #2
QuoteOriginally posted by twitch Quote
Tripod: 2s timer, manual exposure, ISO100
Flash: iso640, manual exposure
Sport: hi continuous, TAv mode, AF linked to shutter button, af expanded area
Thanks, twitch, and for the sport how are the E-Dials (front and rear) set?
04-17-2014, 02:57 AM   #3
Bob from Aus's Avatar
My settings are designed to switch to flying birds, so it's a vairiety of starting points dealing with autofocus and aperture. It would be useless if I couldn't have continuous focus.
04-17-2014, 03:09 AM   #4
QuoteOriginally posted by Bob from Aus Quote
Can you give some more details?
I want to make something like U1 = fast (ISO fixed to 500, max aperture, AFC) U2 = very fast (ISO fixed to 1000, ...) and U3 = I don't know?!
Probably the front dial to be set for ISO.
So if I make some landscape pics on tripod I have enough time for the right settings, but if I see suddenly a bird or other animal I would like to change it to a fast setting immediatelly. But I am not sure which will fit me the best so I think its better to try some of your already tested setting.
04-17-2014, 07:18 AM   #5
u1 TAV center weight exposure, select center 27 point aF. U2 TV, same exposure and af. U3 spot focus spot AF. All at 1/800 auto iso, the TAV at f8. In Tv mode the back dial is exposure compensation.
04-17-2014, 09:09 AM   #6
aleonx3's Avatar
Aside from those (such as birds-in-flight, and using flash) mentioned by other posters, I added one user mode for mounting m42 lenses which I will have shooting mode Av with auto-ISO and also, AF adjustment of -10 (this is important as my k-5 and k-5IIs are FF using manual focus). I also added another user mode for mounting k/m lenses which I will have shooting mode M and AF adjustment of -10 as well.
04-17-2014, 12:06 PM   #7
QuoteOriginally posted by mocker Quote
I need to switch quickly for bird photography so there are two settings one for flying birds and the other to use flash. As yet, I am not using U3
U1 - AV - F5.6, Autofocus AF S (RAW)
U2 - (for bird flash photography) X (180sec) F9.0, AF S, (RAW)
dslr, k-3, k3, pentax k-3, u1, u2
U1 and U2 forget raw setting nigeldodd Pentax K-30 & K-50 2 06-18-2013 09:22 AM
People U2 Velja Photo Critique 2 01-02-2012 11:01 AM
U2 & Green Day "The Saints Are Coming" jogiba General Talk 1 05-24-2010 06:42 PM
All times are GMT -7. The time now is 05:21 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
