05-05-2014, 08:36 AM   #1
How to get ISO above 3 200 in green- and rec-mode?
Hello!
First I want to apologize for my spelling and grammar, English is not my native language but I'll try to explain my question as clear as I can.
This is my first post here at Pentax forums. I've been a Pentax user for about six years, using a K200D, but when I a couple of days ago bought a K-3 I got a problem.
According to these Youtube-videos:
and
it's possible to use ISO up to 51 200 when filming. The problem is that I can't find out how to do that. I have tried several settings but the ISO ends at 3 200 in rec-mode. The same with the auto ISO in green mode, the ISO never goes above 3 200. However, in all other modes, semi- and full manual, I can, manually, use ISO from 100 - 51 200 without any problem. TAv mode follows whatever I have I have put in the auto-ISO settings in the menu and can go all the way up to 51 200.
The Auto-ISO setting in the menu (camera symbol / no 2) is set to 100 - 51 200 but it seem that this setting has no effect when using the rec- or green modes, those will still not go above 3 200. The auto-ISO setting in the menu is also accessable in all modes except for green where it's greyed out and it don't seem to be any ISO-setting dedicated to filming.
In short:
When the Auto-ISO setting in the menu is set to 100 - 51 200:
Auto-ISO in green mode goes up to 3 200
Auto-ISO in TAv mode goes up to 51 200.
All semi-manual and full manual modes can use ISO 100-51 200 with the exception of rec-mode that stops at 3 200.
The firmware is 1.03.
So, I guess that I've just mixed something up or misunderstood something, but what? How can I make the iso in the green- and rec-modes go above 3 200?
Thanks in advance.
05-05-2014, 09:34 AM   #2
Tjompen1968's Avatar
The first video is made by "WorldofDSLR" and I have no idea where this guy gets his or hers ideas but pretty much all from that user i BS.
The second video I have no idea but the K-3 stops at ISO3200 when it comes to video.
---------- Post added 05-05-14 at 06:35 PM ----------
When it comes to green mode the camera descides for you and maximum ISO is 3200. Use P -mode if you want full auto but higher ISO
05-05-2014, 10:37 PM   #3
Maybe i´ts recorded with an external recorder.
05-06-2014, 09:34 AM   #4
Thanks for answering!
I see, so if the guy behind "WorldofDSLR" are unreliable maybe both those videos are fake. If that's the case I wonder why Ricoh has decided to limit the maximum ISO for filming and the green mode to such a low number. A bit strange I think when the K-3 is able to produce good quality images in higher iso than that. ... But that maybe belong to another discussion.
Yes i know that the green mode is fully automatic, P is by the way a great invention. :-)
auto-iso, dslr, filming, idea, iso, k-3, k3, menu, mode, modes, pentax, pentax k-3, tav, video
Best settings to hand to a stranger in 'almost point and shoot'/green mode? rtpguy Pentax K-5 12 10-18-2011 10:44 PM
How to change ISO in Manual Mode closekd Pentax K-r 2 07-04-2011 09:26 AM
K-x Manual Mode only to ISO 200? Ira Pentax DSLR Discussion 9 03-01-2010 02:48 AM
How to ISO in "P" Mode Stratario Pentax DSLR Discussion 6 05-12-2009 05:43 PM
K10D and ISO above 200 Trub Pentax DSLR Discussion 31 06-15-2007 10:42 PM
All times are GMT -7. The time now is 03:11 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
