05-10-2014, 10:52 PM   #1
hcc's Avatar
UHS Memory card & burst rate
I use regularly High continuous burst rate and I would like to hear from K-3 owners using regularly this mode.
I did some limited tests in continuous shooting (H) and I achieve 7 fps with a UHS-I card:
7 fps with JPEG file L* & Sandisk ExtremePro 95 Mb/s 8Gb
Edit: The settings were AF.S, with a DA15mm Ltd and I shot between 10 to 25 shots per burst.
I noted that the Imaging Resource tests were very close to my own results in continuous shooting (H)
7.07 fps with Large/Fine JPEG & SanDisk Extreme Pro 95MB/s UHS-I SDHC card (for up to 75 frames)
7.12 fps with RAW DNG & SanDisk Extreme Pro 95MB/s UHS-I SDHC card (for up to 25 frames)
In comparison, the DPreview tests claimed a higher burst rate with a Class 3 (UHS-II) card in continuous shooting (H):
8.8 fps with Large/Fine JPEG & SanDisk Extreme Pro UHS-3 SDXC card (for up to 68 frames)
8.9 fps with RAW DNG & SanDisk Extreme Pro UHS-3 SDXC card (for up to 23 frames)
I found interesting that my limited results compare closely with the tests of Imaging.resource. They differ from Pentax specs and PF in-depth review and DPR review.
Has anyone compared the burst rate of the K-3 with UHS-I and UHS-II cards?
Have any one had any problem with the UHS-II cards?
Thank you in advance for your input.
05-10-2014, 11:28 PM   #2
The K3 doesn't have the hardware for uhs ii, so that shouldn't make a difference. Perhaps AF delays were to blame in your case?
05-11-2014, 12:03 AM   #3
OregonJim's Avatar
The burst rate should not change, regardless of what type of SD card is inserted - the data is going directly to the camera's internal buffer. The only thing that will change is the number of shots you get until the buffer is full. A faster card will allow the buffer to empty faster.
05-11-2014, 08:30 AM   #4
wtlwdwgn's Avatar
I noticed that the burst rate slowed down in AF.C with half press AF in high speed. I switched to back button AF and the burst rate seems to be unaffected. I also noticed that the buffer empties much faster with a 600x UHS I card Just my two cents.
burst, burst rate, card, dslr, fps, frames, hi continuous shooting, jpeg, k-3, k3, pentax k-3, rate, sandisk, tests, uhs-i
K-3 AF Speed, SDM, and Burst FPS Rate wtlwdwgn Pentax K-3 14 04-07-2014 01:49 PM
UHS-II Memory Cards on K3 dltorre Pentax K-3 4 03-05-2014 02:34 PM
For Sale - Sold: Lexar Professional 400x 32GB SDHC UHS-I Flash Memory Card black-kx Sold Items 0 01-21-2014 05:06 PM
B&H Memory Card Deals Adam Pentax Price Watch 9 12-15-2013 12:04 AM
32GB SDHC Memory Card Ultra Class 10 UHS-I $18.95 w/free shipping @ B&H jogiba Pentax Price Watch 35 06-14-2012 04:26 AM
All times are GMT -7. The time now is 02:33 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
