In a previous thread (
https://www.pentaxforums.com/forums/172-pentax-k-3/261483-uhs-memory-card-burst-rate.html), I reported some very preliminary tests on the burst speed of the Pentax K-3 in High continuous shooting mode. I obtained then results comparable to the review results of imaging-resource.com, but below the results obtained by Adam in the in-depth review and definitely below the review results of dpreview.com. In the discussion, Adam suggested that there might something to do with AF mode, while member
wtlwdwgn mentioned something about half pressing AF.
So I went back to some basic tests that I will list below.
In summary: using a MF lens, I achieved performances of 8.2 fps (H) and 4.6 fps (M) in line with Adam's review results.
A important point hinted by member
wtlwdwgn: you need to keep pressing (relatively hard) the AF button for the full duration of the burst. As soon as you release the pressure on the AF button, I found that the burst rate dropped.
I hope to continue further tests. I use Hi continuous shooting all the time and I believe that the shooting mode is great, quiet and perfect for any action shooting. Anyone with his/her own data on the burst speed is welcome to add these to the thread below to assist other users.
My limited data - Bursts of less than 7 s - MF lens - JPEG files L (* and **)
Hi - Tests with VL58mm MF
8-9 fps with JPEG file L* & Sandisk ExtremePro 95 Mb/s 8Gb (Average: 8.2 fps)
Med- tests with VL58mm MF
4-5 fps with JPEG file L* & Sandisk ExtremePro 95 Mb/s 8Gb (average: 4.6 fps)
