05-30-2014, 05:22 PM   #16
I think you were too far away to get a great shot, regardless of camera. Deer are skittish but you will occasionally sneak up on one - you and the deer will both be startled. The trick IMO is to keep the camera ready so you can get photos before the deer runs away.
05-30-2014, 07:43 PM   #17
Shanti's Avatar
QuoteOriginally posted by Serpiente Quote
buy buy buy
good idea but want the Sony A7s I think,only price is waaay too much ..still hoping Pentax does a FF in my lifetime
05-30-2014, 10:23 PM   #18
QuoteOriginally posted by Shanti Quote
If you want high-ISO (and money is no object), probably better to get the 645Z. I suspect it's high-ISO will match the A7s. Plus you get tons more detail.
06-01-2014, 01:38 AM   #19
Don't expect it to cost much less than the A7 series - just expect it to work better with Pentax lenses!
06-01-2014, 06:49 PM   #20
Shanti's Avatar
QuoteOriginally posted by DSims Quote
if Pentax can max out a FF sensor like they do with APS,then price is not a problem
06-02-2014, 06:31 AM   #21
FF is not the answer. It would make the deer in the top photo appear even smaller and require more cropping.
06-02-2014, 09:19 AM   #22
mattb123's Avatar
Here's a deer shot with a K-3. See how much nicer they come out?
In all honesty I think you would be better served with a longer lens with support or bolder deer. Although the increased K-3 resolution should help with cropping too, reducing the need to crop would be better.
06-02-2014, 11:16 AM   #23
narual's Avatar
This might be a better investment than a new camera body
Amazon.com: Mighty Deer Lick 22341 Sugar Salt Lick Block: Everything Else
06-05-2014, 04:51 PM   #24
tabl10s's Avatar
Question..
for this type of shot I need to use ISO3200 F5.6 1000sec (only used 500) to get the deer sharp while it is running full speed away from me.
This is with the K5II. DA*300 + HD DA 1.4 TC handheld
since I have to crop would I get a better image with the K3? as it seems the K5II has better high ISO, but of course the K3 has more MP
I am trying to find the best solution for this type of shot,which was also handheld. ISO 6400 or greater would give me a faster shutter speed but noise would make it look unsharp
any help is appreciated
I'd shoot raw to get all the fine detail on a hairy butt...
300mm, advantage, bit, camera, crop, dslr, focus, iso, k-3, k-5, k3, k3 k5ii hd da tc 1.4, k5ii, pentax k-3, tc, type
Ideal uses for this kind of three lens kit? incidentflux Pentax K-30 & K-50 10 05-19-2013 10:18 AM
K5 poor focusing accuracy in anything other than bright sunlight? K5II any better? frstep Pentax K-5 18 03-19-2013 08:11 AM
Do they make this kind of case for Pentax DSLRs? neely615 Pentax Camera and Field Accessories 11 11-13-2009 03:02 PM
What do you think about this kind of photography ? netuser Photographic Technique 15 06-23-2009 05:32 AM
what kind of film do you think this is? Gooshin Pentax Film SLR Discussion 4 01-21-2009 08:54 AM
All times are GMT -7. The time now is 09:23 PM. | See also: NikonForums.com, part of our network of photo forums!
