06-05-2014, 03:31 PM   #1
Bob Harris's Avatar
How to upload photos from K3 to computer
I just purchased a K3 and formatted the memory card but can not get photos to upload to the computer. I used the USB cord that I have always used on my K5, any ideas? thanks Bob
06-05-2014, 03:34 PM   #2
QuoteOriginally posted by Bob Harris Quote
The cord should work, but make sure it's attached securely. The K-3 supports USB3 which has an wider connector, which sits a bit more securely in the port.
06-05-2014, 03:34 PM   #3
jatrax's Avatar
What kind of computer? Mac or PC? When you plug in the cable does the computer recognize something was plugged in? Have you tried copying from the SD card instead of the cable?
06-05-2014, 03:50 PM   #4
Bob Harris's Avatar
Adam, I'm plugging it into what says HDMI, right?
---------- Post added 06-05-14 at 02:52 PM ----------
It's a PC, plugging into computer does not get recognized. How do I copy from a SD card? Never done that.
06-05-2014, 03:54 PM   #5
OregonJim's Avatar
How did you do that?
The K-5 has a USB2 connector. The K-3 is USB3. The connectors are different.
06-05-2014, 03:59 PM   #6
OregonJim's Avatar
No. HDMI is a video output port. The long connector above the HDMI port is USB3.
06-05-2014, 04:03 PM   #7
I usually take the card out of the camera, and then put it into the SD Card slot on the PC. Folder pops up, drag and drop.
When I have tons o' pics, I grab the USB3 cable, plug it into the USB port on the K-3, then plug into the USB3 port on the PC... folder pops up, drag and drop.
I didn't have to install any software or drivers, the PC took care of anything or everything I needed.
06-05-2014, 04:03 PM   #8
Bob Harris's Avatar
It was real tight and I thought I had the wrong insertion point. I put it into the other port and I get a message that the USB device not recognized.
06-05-2014, 04:04 PM   #9
QuoteOriginally posted by OregonJim Quote
The K-5 has a USB2 connector. The K-3 is USB3. The same cable will not fit, the connectors are different.
You can use the USB2 cable on the K3, it just won't get the speeds of USB 3 (as it is lacking the extra connector)
06-05-2014, 04:07 PM   #10
Bob Harris's Avatar
QuoteOriginally posted by calculator01 Quote
I have it plugged in but it comes back on the computer the usb device is not recognized.
06-05-2014, 04:13 PM   #11
OregonJim's Avatar
You may have damaged the HDMI connector on your camera and/or the cable from your K-5.
The only place it will fit is at the very top end of the long USB3 connector on the side of the K-3. There, it should work as a standard USB2 device.
06-05-2014, 04:16 PM   #12
Hmmm...I am able to connect my K-3 with a USB2 cable to both my Windows 7 (64 bit) computers. The K-3 is detected as an external USB drive.
---------- Post added 06-05-14 at 04:18 PM ----------
Bottom end. It accepts a USB Micro B the same as my Samsung cell phone. The top section is for the USB3-specific pins.
It is a rotten shame that Ricoh chose not include appropriate USB and HDMI cables with the camera. Shame on you Ricoh!!!
06-05-2014, 04:19 PM   #13
Bob Harris's Avatar
I tried another cable, you're saying it should be connected to the top connector of the 2 available?
06-05-2014, 04:32 PM   #14
OregonJim's Avatar
Yes, you're right - pardon me. I had the camera sitting upside down in my lap.
06-05-2014, 04:33 PM   #15
Pepe Le Pew's Avatar
What type sd card you using and can your comp handle it?
cable, camera, card, computer, default, dslr, k-3, k-5, k3, message, msc, pc, pentax k-3, photos, photos from k3, plug, post, reader, sd, upload, upload photos, usb, usb cable, windows
How to upload / link photos - BEGINNERS START HERE Adam Post Your Photos! 191 05-17-2017 06:25 AM
Photos Are Being Deleted From SD Card After Transferring To Computer monoloco Troubleshooting and Beginner Help 6 04-16-2014 02:41 PM
Question Unable To Upload Photos DavidSKAF3 Site Suggestions and Help 3 12-17-2013 05:43 PM
how to connect x-5 to computer LynneBH Pentax Compact Cameras 4 06-22-2013 02:35 PM
Photos upload to computer in wrong order markaphone Troubleshooting and Beginner Help 2 08-09-2012 04:35 AM
All times are GMT -7. The time now is 07:15 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
