06-12-2014, 10:40 PM   #16
Otis Memorial Pentaxian
QuoteOriginally posted by kh1234567890 Quote
It is the linear resolution that matters as far as any increased visibility of CA etc. goes. The K-3 sensor is a touch smaller so the pixel spacing is about 3.9um for the K-3 vs 4.8um for the K-5. Less than 25% difference in whichever direction you measure.
I think this is somewhat different than your original assertion and definitely makes more sense. Is this the same as pixel pitch? If I remember correctly it is pixel pitch that influences the theoretical maximum horizontal/vertical optical resolution, which is what counts in this context.
Regardless, I was not impressed with that aspect of the camera review and was still left wondering which Pentax models handled CA better.
06-12-2014, 11:01 PM   #17
I think the camera reviewer is simply used to reviewing other camera makes (eg Nikon), where the in-camera CA correction seems to be turned on by default, and may be more effective than the Pentax default.
Anyway, the CA performance of this lens in the sample image is as expected. As the SLRGear test of this lens reminds us:
"Chromatic Aberration
Below 100mm, chromatic aberration is tolerable - just some light color fringing in areas of contrast, and only in the extreme corners. ..."
which is where we are seeing it here.
Luckily the reviewer in OP's post didn't examine any shots taken with the lens at 100mm or greater . Also from the SLRGear test:
As the lens is zoomed in to 100mm and 135mm however, chromatic aberration is quite prominent, in fact, some of the most noteworthy we've come to see in these tests.
Having said that, CA hasn't really been a problem with my copy of this lens at any focal length.
06-13-2014, 02:21 AM   #18
Or my copy of the K-3
aberration, camera, chromatic aberration, dslr, issue, issues, k-3, k3, lens, lens issue, pentax k-3, review, reviewer, steve, techradar
Optical differences between Pentax "K", "M", and "A" lenses 6BQ5 Pentax SLR Lens Discussion 31 01-10-2014 01:02 PM
Don't say Pentax "Q" in French ... "Q" = "cul" = "A--" Jean Poitiers Pentax Q 52 11-10-2013 06:25 AM
ME super: can I use "M" lens in "auto" setting. treetoile Troubleshooting and Beginner Help 4 03-25-2013 10:03 AM
Pentax K-x False message "No card in camera" wedwardes Troubleshooting and Beginner Help 16 01-29-2013 09:50 AM
Suggestion Add subsections to the "Nature" option in "Post Your Photos" jpzk Site Suggestions and Help 2 07-22-2012 12:04 PM
All times are GMT -7. The time now is 11:38 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
