06-25-2014, 04:15 PM   #1
wahee's Avatar
Pentax K-3 Bizarre 'frying' noise
Hi
I have recently purchased a K-3 camera 3 months ago. It has developed a fault. I only noticed it tonight while trying out some live view shooting in a quiet space.
Once the camera is put into video mode or live view, there is a strange hissing / crackling sound coming from inside the camera! It is very annoying and is the kind of thing as an audio engineer I have head when an electronic component is faulty. It really is quite loud and sounds like the noise one hears if one puts a shell or cup to ones ear. The noise is there if the audio on the camera is up or down
Hopefully Pentax uk will have decent customer service as I think this K-3 will have to go back. Such a pity as the camera takes smashing photos
06-25-2014, 04:19 PM   #2
I think that sound is the shake reduction system holding the sensor in place. My K-r and K-5 make similar sounds during live view.
You don't hear the sound during stills because the SR only works for a moment during stills. In live view the SR system stays on the entire time.
06-25-2014, 04:27 PM   #3
fgaudet's Avatar
Does sounds like it's the SR. It's not very loud on the K3 but you can surely hear it. Just try to turn OFF Shake Reduction and see if it still makes the noise.
06-25-2014, 04:29 PM   #4
QuoteOriginally posted by wahee Quote
Hi
Yup, like others have said, this is the SR system trying to keep the sensor steady. The sound can't be avoided on cameras with in-body SR.
06-25-2014, 05:04 PM   #5
fgaudet's Avatar
QuoteOriginally posted by fgaudet Quote
Yeah I just checked my K3 and my K5 and when in LiveView they do makes the sounds, SR ON or OFF (maybe a bit fainter with SR OFF). So disregard this "test"...
06-25-2014, 05:35 PM   #6
Age cures the problem. Age of the photographer that is. I've lost enough high frequency sensitivity to not really notice it.
06-25-2014, 06:38 PM - 1 Like   #7
It's very noticable with the Pentax Q also.
06-26-2014, 02:37 AM   #8
wahee's Avatar
hi
First up I appreciate the replies on this.
I have just tried the camera without SR on and the noise is still there. It sounds like a crackling or hissing. Like small gremlins having a fry up. Not very scientific I know but imagine an audio amplifier turned up but with no signal input. Like it's amplified noise.
I can hear it from about 3 feet away from the camera. The noise is also irregular. i.e no like a servo or some sort of regulatory system, more random.
I have contacted Pentax service and they say they will take a look at it. I can't imagine this is normal on such a high end camera
06-26-2014, 04:05 AM   #9
chromo's Avatar
Hmmmm. Interesting.
Please post back with the outcome.
06-26-2014, 05:03 AM   #10
wahee's Avatar
hi yes I will do.
07-03-2014, 04:04 AM   #11
I bet it was normal.
I guess it's one of the most common questions there is about Pentax cameras, right after the "something is loose inside my camera" question, which is also very popular.
07-03-2014, 04:33 AM   #12
Transit's Avatar
Yeah my K-01 sounds like it's frying chips
07-03-2014, 08:35 AM   #13
maleek's Avatar
Like everybody else, pretty much, I too experience this. The noise reduces significantly turning the SR off, but not entirely. It makes me vary of filming with it, I pretty much mostly use it as the excellent stills camera it is.
07-03-2014, 10:37 AM   #14
awaldram's Avatar
hi
SR on = sensor held central and adjusted for camera movement with powerful electro magnets generates 500Hz hum
SR Off = Sensor held central with powerful electro magnets generates 500Hz hum
It doens't matter sr on or off the sensor is always moved from rest to central position by electro magnets these buzz.
If you use the psuedo AA this alse generates a seprate niose as a sine wave in transpposed onto the the sensors electromagnets to generate the required blurr factore
07-06-2014, 12:27 PM   #15
I had a similar sound on mine. Turned out it was the anti aliasing filter simulator that was switched on. When the aa simulator is off, the camera is dead silent.
camera, dslr, k-3, k3, live, noise, pentax, pentax k-3, view
K-3 Noise Lurch Pentax K-3 & K-3 II 28 01-17-2014 06:56 AM
K-5 noise even with ISO 200 (was: K-5 IIs noise) lunany Pentax K-5 & K-5 II 9 12-28-2013 06:54 PM
Excessive noise in new K-3 davidreilly3207 Pentax K-3 & K-3 II 31 11-23-2013 02:41 PM
Bizarre behavior K-5 and Metz 58-2 flash MSL Pentax K-5 & K-5 II 15 03-19-2013 10:51 PM
Bizarre Noise On My K7 Images!!!! Christopher M.W.T Troubleshooting and Beginner Help 64 07-18-2009 01:17 AM
All times are GMT -7. The time now is 02:24 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
