07-15-2014, 09:31 AM   #1
nicoprod's Avatar
K-3 av mode with minimum shutter speed
Hello,
Is there a way to shoot aperture priority with the K-3 and set the shutter speed to a minimum of (say) 1/80s so it doesn't go slower? I'm not talking about TAv where the shutter speed is locked at a specific speed, instead I want to prevent it to go too slow (even if it would be under exposed).
Also, in the same mode, is there a way to automatically fire the flash (P-TTL) IF and ONLY IF the shutter speed wants to go slower than (say) 1/80s to get proper exposure?
I hope this make sense.
Thank you!
07-15-2014, 10:42 AM   #2
MJSfoto1956's Avatar
+1 on the ability to set limits on different modes. It is a good idea with a lot of merit. Either that, or allow users to configure and "tune" the algorithms for auto exposure for each mode.
Michael
07-15-2014, 10:47 AM   #3
nicoprod's Avatar
The Nikon D700 does it.
07-15-2014, 11:01 AM   #4
Otis Memorial Pentaxian
No and No. Both are great ideas though and could be implemented in much the same way as the auto-ISO limits are handled.
---------- Post added 07-15-14 at 11:02 AM ----------
QuoteOriginally posted by nicoprod Quote
Good reason to buy the Nikon...or not...
---------- Post added 07-15-14 at 11:05 AM ----------
QuoteOriginally posted by MJSfoto1956 Quote
Michael
This is yet another reason why it would be nice if Pentax were to support an API (at least on their flagship models) via the USB port to allow something similar to the Magic Lantern utility available to Canon users. Not that Canon has been particularly cooperative with the folk at Magic Lantern, however
07-15-2014, 01:04 PM   #5
+1 on open APIs -- let developers enhance your products. Canon has a readily hackable API. Nikon is super secret about theirs. Pentax seems to be in-between
m
07-15-2014, 01:34 PM - 1 Like   #6
What's wrong with Manual mode?
07-15-2014, 02:11 PM   #7
plenty. If you are at a typical concert these days, the lighting often varies wildly, sometimes second to second. Manual exposure would be dreadful in such a situation.
M
07-15-2014, 02:48 PM   #8
You can always imagine a scenario against using Manual mode. However, my question was directed to the OP (you'll notice I quoted him). We don't yet know the shooting conditions which prompted opening a thread. If we know more about that then we'll have a better chance of helping him with his question.
Personally I find M mode pretty fast, but that's only because I'm used to using it. So again, to the OP - what's wrong with M mode. Can you expand on this?
Cheers
07-15-2014, 04:05 PM   #9
I don't have a K-3 but on my DSLR I'd just put the camera in auto-ISO and set the minimum shutter there while in aperture priority and get it done that way. Does that work on the K-3?
07-15-2014, 05:23 PM   #10
Nope. You are still shooting with a D800 and dF, right?
07-15-2014, 06:06 PM   #11
JinDesu's Avatar
Alternatively, TAv?
But yeah, the k-3 won't let you set the minimum shutter speed as far as I can tell.
07-15-2014, 06:28 PM   #12
Tv or TAv. Let the auto-ISO handle the lighting. When you are shooting a concert, you are probably going to hold to a certain shutter speed anyhow, depending on your lens focal length, your distance from the stage, and the kind of gig it is (piano player shot wide with a 50mm = keep a slower shutter than rock vocalists shot close at 200mm). And at gigs you are usually going to hold your lens at a pretty constant wide-open or near to it aperture too (eg f2.8-f4). So at a gig neither shutter or aperture will usually need to operate across a terribly wide range.
TAv with Auto-ISO does, close enough, IMHO.
One can also switch to P mode and tune the Program Line response to suit your shooting needs, of course (High Speed priority, DOF priority, MTF priority etc). Or use the Green Button to quickly adjust same while in TAv or other modes.
A shutter speed floor limit for auto-ISO and other modes would be nice, I guess. I'm sure it wouldn't be impossible for Ricoh to implement. Maybe Nikon, however, patented it or something?
07-15-2014, 07:52 PM   #13
I see. I use that feature a lot! When you don't have in-camera stabilization and not using a lens with VR, setting minimum shutter speed is a must.
07-15-2014, 10:13 PM   #14
Yep! Of course back-in-the-day the better cameras showed the shutter speed in the viewfinder when using Av mode and we simply got used to monitoring the reading as we shot. The Canon shooters simply used Tv mode and depended on fast glass.
07-16-2014, 04:41 PM   #15
dosdan's Avatar
You can't specifically select Auto-ISO with TAv, since TAv already does Auto-ISO. You can select Auto-ISO with M though.
Are you aware of any operational differences between TAv and M+Auto-ISO? I've not noticed any.
Dan.
dslr, k-3, k-3 av mode, k3, mode, pentax k-3, post, reason, shutter, steve, users
Av mode shutter speed Samyang 14mm/2.8 DeadJohn Troubleshooting and Beginner Help 14 12-05-2013 03:36 PM
min shutter speed in Av mode with flash WMBP Pentax DSLR Discussion 32 03-31-2010 02:37 AM
K-x Av mode shutter speed question macky112 Troubleshooting and Beginner Help 9 03-24-2010 10:13 AM
K-x Av with auto-ISO: slow shutter speed issue Karellen Pentax DSLR Discussion 6 02-22-2010 03:58 PM
AF-360FGZ on K20D Slow Shutter Speed in Av Mode Peter71 Pentax Camera and Field Accessories 3 09-11-2008 07:37 PM
All times are GMT -7. The time now is 03:10 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
