Originally posted by awaldram The sort of lcd damage that will require 'service' no protector in use today will aviod, At best they protect against mild sctratches which are incredibly rare
Not referring to damage... referring to the degrading of the display.
Never saw a screen protector degrade the screen to the extent that it warranted not using one.
Unlike UV filters which under some situation have very obvious effects.
Not really comparing equivalent situations.
Additionally, if that LCD screen breaks, glass will likely fall all over everything and risk cutting your face and fingers if you continue to use the camera. A screen protector will help hold all of that together and maybe even help prevent it from damaging the LCD beneath. It might even continue protecting against dust and moisture for a while.
Again, the UV filter does none of these. Cases have even reported broken UV filters to have scratched the front element whereas the impacting object may not have caused any damage without the filter.
So, again, not a one to one comparison.
Anyway, as has been said. Personal choice. Whatever you're comfortable with.
For my environment, its well worth it with no apparent risk factors for doing so.
