07-20-2014, 03:28 PM   #16
I just did a quick test using DA 50/1.8, FA 35/2, A 50/1.7, and K 55/1.8:
  • Manual focus mode
  • M exposure mode
  • 1/1000s shutter speed
  • Frame rate on "H"
I was not able to discern any difference in frame rate between the lenses listed.
Edit: Did a fresh listen and sure enough, when aperture is controlled by the aperture ring on the lens, the maximum frame rate is lower. At least that is the case when the aperture is set to wide open. At f/22, the rate sounds about the same.
This makes sense if you think about it. The time to complete the open-close-open sequence depends on the chosen aperture. When the body is doing the setting, it is in the position to cycle faster for the wider apertures.
End Edit
07-22-2014, 07:40 AM   #17
hello
I thought it may be some noise processing. You could try turning it off.
07-25-2014, 11:25 AM   #18
The aperture needs to open/close fast enough. Slow apertures could be a problem - 7 fps is faster than allowed during M and A lens times.
I think it is a physical limitation. I ones worked a Canon SSC 50 lens hard on a T90 with 4.5 fps and saw the aperture ring moving caused by the shake of the camera... at that time a film would last for 7 seconds or so.
dslr, fps, k-3, k3, max, pentax k-3
FPS while shooting K20D in Continuous Lo until card fills up? kenyee Pentax DSLR Discussion 11 07-12-2012 09:13 AM
Continuous shooting with shoe-mounted flash slower, but not in Live View bwDraco Pentax K-r 5 07-12-2011 09:57 AM
Canon EOS 550D with full manual control and 1080p 30 FPS. Firmware update time now? netrex Video and Pentax HDSLRs 17 02-10-2010 12:13 PM
K-7 & slower FPS with system flash kolouch Pentax DSLR Discussion 9 10-04-2009 02:18 AM
Why are DAs made with slower glass than FAs? loganross Pentax SLR Lens Discussion 21 03-08-2007 03:27 PM
All times are GMT -7. The time now is 11:15 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
