08-20-2014, 05:49 PM   #1
New lenses for the K3
Well, my new K3 is in and I can use the few Pentax lenses I had for the Kx just fine. They are : a 55-300mm, a 50-200mm and a Tamron 10-24mm. If I can get 3 new lenses, ones that are not awfully expensive, what would be my best choice? I am looking at a 50mm, a 35mm, and a macro. Would that seem reasonable?
Thank you for any advice you may care to share.
mariakruse
08-20-2014, 06:42 PM   #2
QuoteOriginally posted by mariakruse Quote
mariakruse
Would suggest the da 50 mm 1.8, 35mm f2.4 and if you want a cheap 100mm macro the M series 100mm f4 has been a great buy if you don't mind manual focusing. In the USA You can get that lot ford under 500usd
08-20-2014, 06:51 PM   #3
clackers's Avatar
Three great suggestions. You want the macro to be MF anyway! :-)
08-20-2014, 06:59 PM   #4
Des
Des's Avatar
If you say a bit more about your shooting preferences and budget you will get more targetted advice.
08-20-2014, 07:33 PM   #5
QuoteOriginally posted by mikeodial Quote
Thank you, those two, the 50 and the 35 were on my list and I was planning to get them next week. They are in my cart at Amazon.
maria
---------- Post added 08-20-14 at 08:34 PM ----------
I think you are right, I do a lot of close up work.
maria
---------- Post added 08-20-14 at 08:37 PM ----------
QuoteOriginally posted by Des Quote
I'm sorry, you're right. I should have been more specific. I do mostly still life and landscapes as well as trying to create some abstract pieces . When I need a bit of money for more gear I do pet portraits.
mariakruse
08-20-2014, 07:43 PM   #6
Sigma 17-70 2.8-4 DC HSM Contemporary is my suggestion. Very sharp and is close focusing. The Sigma 105 macro EX DG can be found at reasonable prices also.
08-20-2014, 08:29 PM   #7
I could only find the 105mm Sigma used. Is it no longer made? What do you think of the Tamron AF 90mm f/2.8 Di SP A/M 1:1 Macro Lens for Pentax ?
maria
08-20-2014, 08:49 PM   #8
Des
Des's Avatar
maria
Each variant of Tamron 90 is very highly regarded:
https://www.pentaxforums.com/reviews/tamron-90mm-macro-vs-pentax-100mm-wr/introduction.html
http://www.photozone.de/pentax/362-tamron-af-90mm-f28-di-sp-macro-pentax-
https://www.pentaxforums.com/userreviews/tamron-sp-af-90mm-f28-macro-11-model-172e.html
https://www.pentaxforums.com/userreviews/tamron-sp-af-90mm-f2-8-di-macro.html
08-20-2014, 08:59 PM   #9
The Tamron will do you good also. The Sigma 105 I was able to find new but is available used. The Sigma 17-70 is less than a year old and costs $450.00 to $500.00 but is worth it.
08-20-2014, 09:54 PM   #10
Des
Des's Avatar
As for the wide to short-telephoto range, the anterior question is whether you need primes or a good zoom (e.g. Tamron 17-50 or the Sigma 17-70 C mentioned above). This is a common discussion in relation to pet photography:
https://www.pentaxforums.com/forums/10-pentax-slr-lens-discussion/195277-reco...portraits.html
You will see in that thread that some people suggest a Tamron 28-75mm f2.8. Fast and sharp enough. Would nicely complement your 10-24 and 55-300.
However I take it from what you have said that you are already leaning towards primes, and particularly the plastic fantastics (DA 35 and DA 50). You can't go wrong with these lenses. There is a whole thread of photos taken with them so you can see for yourself.
Some people will argue for other prime lenses in the normal to short-tele range, like the three amigos (FA 31, 43 or 77), the 40 ltd, 35 or 50 macro, DA*55 or 70. Most of these are more expensive, but if you are using a lens for pro photography could be worth the investment.
08-20-2014, 10:53 PM   #11
clackers's Avatar
maria
It's the one I use, Maria - like it a lot. Has AF too and can double as a portrait lens at a pinch.
08-21-2014, 02:22 AM   #12
Tjompen1968's Avatar
maria
Sharp as a razor. My goto lens for portrait and macro.
08-21-2014, 06:04 AM   #13
bdery's Avatar
QuoteOriginally posted by jb0501 Quote
That's a great all-around lens, I'd have recommended it but you seem to be interested mostly in primes.
If you want to keep the price down, either look at a used F50 f1,7 (to be had for about 180$) or a new DA50 f1,8. Both are great. You want a 35 AND a macro, why not look at the DA35 f2.8 macro limited? Two birds with one stone. If you want macro to photograph critters 35mm is not very long, you'll be very close to the bugs, otherwise it is a fantastic lens.
08-21-2014, 07:17 AM   #14
Yes, good suggestion. Or, since the OP also mentioned a 50mm prime, there's the D FA 50mm F2.8 Macro.
@mariakruse, what are your goals for the macro? If you want closeups of insects you might prefer something in the 100mm range for more working distance, but a 35 or 50 can work for flowers and "still life" macros.
Note that the 35 and 50 macros are f2.8. If your goal for getting primes is ultra-thin depth of field or handheld low light photography, f2.8 might not be enough aperture.
08-21-2014, 08:34 AM   #15
Thank you
maria
---------- Post added 08-21-14 at 09:35 AM ----------
Where did you find the Sigma new?
thank you
maria
---------- Post added 08-21-14 at 09:41 AM ----------
Thank you, lots to think about now.
maria
---------- Post added 08-21-14 at 09:43 AM ----------
It looked pretty good to me.
maria
QuoteOriginally posted by Tjompen1968 Quote
Thank you.
maria
---------- Post added 08-21-14 at 09:48 AM ----------
What please, does the FA mean?
Not only interested in primes, but wanted to get what I was told were the "standard lenses everyone should have" first before I plunged into the world of zooms.
maria
100mm, af, bit, dslr, fa, frame, k-3, k3, lens, lenses, lot, macro, maria, pentax, pentax k-3, plenty, pm, post, primes, review, sigma, sp, tamron
lenses for k3 mariakruse Pentax K-3 3 08-16-2014 01:28 PM
New K3 or Better Lenses ROBEFFY Pentax DSLR Discussion 15 05-02-2014 02:31 PM
Kit lenses - are they good enough for the K3? regislea Troubleshooting and Beginner Help 24 04-13-2014 10:56 PM
Fast focusing lenses for K3 yorik Pentax K-3 21 04-13-2014 12:18 PM
Preparing for the K3 with great lenses ? jpzk Pentax K-3 4 11-12-2013 03:27 PM
All times are GMT -7. The time now is 07:43 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
