Originally posted by Ken Kelley Thanks. I have the file saved (fwdc220b.bin). Instructions I've found on a web search say to drag the file from where I've saved in to the E:/ drive where I have the card and that will put it in the root file. Is that a safe assumption? Sorry to be so dense but I've not done this before and I want to be sure before I do something stupid.
I think so, just open up the drive to make sure, if you can see the file after you click on the drive once, then it is root folder. If you have to look for it, and open another folder, it needs to be moved. Then stick it in slot 1 of the camera, and turn on camera while holding menu button.
