09-07-2014, 07:58 AM   #1
Should I get a K3?
Right now, I'm using a K30 but find the K3 very interesting. I have a couple of questions for you guys:
1- Is it Worth it to buy a K3 compared to my K30?
2- What exactly is the problem that I read a lot about concerning the mirror that flaps or flops or freezes or I don't know what?
3- Has that problem been solved by the firmware or a factory fix?
4- How do you guys like your K3?
Thanks for any input.
09-07-2014, 08:35 AM   #2
Ahab's Avatar
I've had mine since January. Never had a mirror flap or freeze. I love it, best camera I've owned and I had a bunch.
09-07-2014, 08:46 AM   #3
jatrax's Avatar
1) only you can decide. It is a completely different camera as far as features and ergonomics, and has a completely different sensor and AF system. It is certainly a great step up but whether you should or not is up to you.
2) The mirror flap is when the mirror on the camera starts flapping uncontrollably. I have just under 16,000 actuations on mine and have had mirror flap twice. Dropped the battery reinserted, back shooting in like 5 seconds. I know there are some very upset about this and I cannot speak for them but for me it is just completely a non-issue. For what it's worth both times it happened to me I was using the DA 12-24 and it has never happened with any other lens.
3) There is a factory fix that Ricoh says will fix it if you camera is affected. There is also a firmware update that is supposed to monitor for it and reset the camera if it occurs.
4) Easily the best camera I have ever used. The only camera I have ever bought at launch sight unseen. And I have owned the k-x, k-5, k-5IIs and now k-3. It is a workhorse that can go all day and deliver great images. I know on this site you are not supposed to say anything good about Pentax, but sorry I'm a big k-3 fan.
09-07-2014, 08:47 AM   #4
wtlwdwgn's Avatar
I bought mine in April and love the quality of the images. I had one episode of the mirror flop but it's not done it since. Ricoh has a warranty fix and there's also updated firmware. The K-3 is a better tool and it will record better quality images but it won't make us better photographers. Just my $0.02.
09-07-2014, 09:56 AM - 1 Like   #5
only if you already have nice glass. if not, invest in that first.
09-07-2014, 12:30 PM   #6
Insanely humble
savoche's Avatar
QuoteOriginally posted by VE2CJW Quote
1 - Hard to say. The K-3 is better in most ways, but for pure image quality you might well be better off buying better lenses rather than a K-3.
2 - Whatever problems there are they seem to have gone away after firmware 1.11 came out. At least that's my impression from the "mirror flap" threads.
3 - See above
4 - A lot Compared to the K-5 I like most of the changes; speedy action, (mostly) better controls, better view finder, better live view. But a bit heavier.
QuoteOriginally posted by grispie Quote
...and this. Not that my "not best" lenses are any worse than before, but their weaknesses are a lot more obvious when I study a 24 MP image at 100 %.
And my best lenses have become quite a lot better. The DFA 100 Macro shines on the K-3.
09-07-2014, 05:23 PM   #7
QuoteOriginally posted by savoche Quote
3 - See above
Thanks for your input guys. Take care.
Mike.
09-07-2014, 06:57 PM   #8
fgaudet's Avatar
I can't say about K-30 to K-3 but I can say that K-5 to K-3 does make a pretty big difference.
Better lenses will more than likely make a more significant difference in image quality than the body upgrade would. However, everything on the K-3 is a bit better than the K-30 (AF, 14bit RAW, better sensor, faster burst rate, larger buffer...) and you do get a few new features (like mirror lock-up, dual SD and top LCD).
The K-3 will not make average lenses look worse but I noticed a significant improvement in higher end glass, the DA* are just amazing paired with the K-3. Even some old M42 or A and K lenses I have handy really shine on the K-3 where on the K-5 they were just so-so.
I prefer using the K-3 vs the K-5, more so than I preferred the K-5 against the Kr.
I was off to a rough start with the K-3 in the first few weeks. I had a bunch of odd, mostly annoying things happening but I never experienced the flappy mirror issues, and none of these happened after the second firmware upgrade (can't remember which version it was). I use my camera for everything, long exposure, burst shooting, time lapse, with no grip, with a modified DG4 grip, with cheap china batteries, in the cold, under the rain, in sand storms, you name it...
I'm very happy with it, I would not change it and I sure don't regret the expense.
09-07-2014, 11:30 PM   #9
I have two bodies, one of them never has had a problem, the other twice with the DA 12-24. Again, dropped the battery out, put it back in and started shooting again. The occurrences were months apart, and none for a long time.
Some have been able to reproduce the problem, and obviously have a hardware issue. Pentax says to send it in for repair.
09-08-2014, 07:11 AM   #10
I recently bought a K-3 and "sold" my K-30 to my son. If a quieter shutter mechanism matters to you, you will instantly like the K-3 for that reason alone. JPEG colors seem to be a little better (accurate) out of the K-3, for those who actually shoot a JPEG now and then. White balance is probably improved a little, too. It's only with special lenses that I think you'll detect a practical difference in sharpness. I'll confess to not even tried P-TTL flash with my 360FGZ but others have commented that it's more accurate on a K-3.
Of course there are several features which may or not matter to you. Things such as selectable program line bias, etc.
09-08-2014, 10:33 AM   #11
jatrax's Avatar
QuoteOriginally posted by derekkite Quote
Now that is interesting, as it has only happened to me with the DA 12-24. Hmmm......
dslr, guys, k-3, k3, k30, pentax k-3
should I get a 50-200 wr lens? tahoejeepmom Pentax SLR Lens Discussion 10 04-01-2014 05:26 PM
Should I get a flash? tahoejeepmom Flashes, Lighting, and Studio 13 06-18-2013 12:21 PM
Just won a KX off ebay =) what should i do till i get it? TheTenaciousOne Pentax Film SLR Discussion 18 10-15-2009 07:53 AM
Should I get a tripod? saien Pentax Camera and Field Accessories 25 09-12-2009 06:35 PM
I think that I should sell my kit and get a Nikon D700! TomInJax Pentax DSLR Discussion 30 09-17-2008 03:23 AM
All times are GMT -7. The time now is 02:02 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
