Something with the write speed of the Sandisk Extreme (45MBs) is about the limit of the K-3 write speed. Sandisk Extreme Pro gains very little, maybe a second or two less to clear the buffer, so not worth getting for the K-3 at least.
I have found that many other cards, like the PNY Elite Performance, don't live up to their claimed speeds. The PNY cards I have are not as fast as the Sandisk Extreme, let alone the Extreme Pro.
---------- Post added 09-10-14 at 10:16 AM ----------
Originally posted by PT1 I did an SD card test recently:
https://www.pentaxforums.com/forums/172-pentax-k-3/266218-buffer-clear-time-m...-sd-cards.html
I didn't need 8 fps for more than 3 seconds, so didn't waste money on expensive 'Extreme Pro' cards (the buffer in the K-3 may mean you possibly don't care too much how fast the data writes to the SD card).
I use different make cards in slots 1 and 2, with DNG RAW to Card 1, and JPG + Video to Card 2.
Get a better lens with the money instead?
Yes, that is the most economical arrangement, as long as you don't need RAW backups. Writing RAW to both cards does take longer to clear the buffer. I decided JPG will be good enough for me.
John.
