Hi there. I just bought a used (but in mint condition, just purchased in one month less than 2000 clicks) K-3, after test tens of clicks I upgraded its firmware from 1.00 to 1.11. After that till now (only 2 weeks), I've met 4 times of failures in 2 kinds, within around 3000 clicks (most in burst mode to shot some basketball plays and my daughter) . One of them seems not ever be reported here (or I missed it in searching), so I report here in a new thread. Any suggestion will be appreciated gratefully.
This is the basic info of my K-3:
Manufacture Date : 2014:03:10
Production Code : 2.1
Internal Serial Number : 7044085
Power Source : Body Battery
1. K-3 stuck in review mode, it didn't response to any operation, even turning the power level to OFF. At last I've got to pull the battery out, and after I pushed it back and power on again, all the settings I modified during the stuck session and pictures in the buffer was lost.
This failure happened twice. Once I was checking pictures while it was storing pictures (SD led was light), after took around 10 clicks during burst mode . After I check couple of pictures, I found I couldn't move forward or zoom in out anymore. Then I tried to half push shutter or turn off the power level, nothing happened, it was still show the same picture. At last I had to pull the battery out and push again, then all the 10 pictures were disappeared.
Settings was in AF.C, all auto focus, matrix meter, H drive mode, TVs F5.6 1/250, no flash, FA*85/1.4, white Toshiba 16G class 10 SDHC card in slot1, JPG L high.
The second time happened to FA*24/2 lens in AF.S, single drive mode, similar condition. The most difference from first time is this failure also happens in single drive mode / focusing mode. At that time there was only one picture in buffer.
2. The other kind of failure I met is mirror lockup while burst mode for less than 1 second, then camera reset internal. I even didn't notice this failure, until it got wrong exposure next click, because the settings I modified was lost during internal reset. Similar settings with first failure. The info of last saved exif is:
Body Battery State : Close to Full
Body Battery Voltage 1 : 6.59 V
Body Battery Voltage 2 : 6.35 V
AF Predictor : 903
AF Defocus : 2
AF Integration Time : 0 ms
Kelvin WB Daylight : 5205 0 2.2890625 1.425048828125
Kelvin WB 01 : 2500 0 1.241943359375 2.566162109375
Kelvin WB 02 : 2630 0 1.305908203125 2.458251953125
Kelvin WB 03 : 2780 0 1.3804931640625 2.340576171875
Kelvin WB 04 : 2940 0 1.4593505859375 2.225341796875
Kelvin WB 05 : 3130 0 1.55078125 2.1026611328125
Kelvin WB 06 : 3330 0 1.6434326171875 1.9893798828125
Kelvin WB 07 : 3570 0 1.7486572265625 1.873046875
Kelvin WB 08 : 3850 0 1.8629150390625 1.759765625
Kelvin WB 09 : 4170 0 1.9815673828125 1.653564453125
Kelvin WB 10 : 4550 0 2.107421875 1.552734375
Kelvin WB 11 : 5000 0 2.2373046875 1.459716796875
Kelvin WB 12 : 5560 0 2.3739013671875 1.3712158203125
Kelvin WB 13 : 6250 0 2.510986328125 1.2906494140625
Kelvin WB 14 : 7140 0 2.6490478515625 1.21630859375
Kelvin WB 15 : 8330 0 2.7847900390625 1.1480712890625
Kelvin WB 16 : 10000 0 2.9141845703125 1.0859375
WB Shift AB : 0
WB Shift GM : 0
EV Steps : 1/3 EV Steps
Sensitivity Steps : As EV Steps
Serial Number : 4976196
Source Directory Index : 0
Source File Index : 0
Level Orientation : Horizontal (normal)
Composition Adjust : Off
Roll Angle : -3
Pitch Angle : -14.5
Composition Adjust X : 0
Composition Adjust Y : 0
Composition Adjust Rotation : 0
Contrast Detect AF Area : 0 0 0 0
Camera Temperature 2 : 26.4 C
Camera Temperature 3 : 26.4 C
Sensing Method : One-chip color area
CFA Pattern : [Red,Green][Green,Blue]
Custom Rendered : Normal
Exposure Mode : Manual
Focal Length In 35mm Format : 52 mm
Scene Capture Type : Standard
Contrast : Normal
Saturation : Normal
Sharpness : Hard
Subject Distance Range : Distant
GPS Version ID : 2.3.0.0
Thumbnail Offset : 152736
Thumbnail Length : 6164
Jpg From Raw Start : 28456096
Jpg From Raw Length : 2760916
Aperture : 4.0
Image Size : 6080x4032
Jpg From Raw : (Binary data 2760916 bytes, use -b option to e
xtract)
Lens ID : smc PENTAX-DA 35mm F2.4 AL
Preview Image : (Binary data 54795 bytes, use -b option to ext
ract)
Scale Factor To 35 mm Equivalent: 1.5
Shutter Speed : 1/320
Thumbnail Image : (Binary data 6164 bytes, use -b option to extr
act)
Circle Of Confusion : 0.020 mm
Field Of View : 38.2 deg
Focal Length : 35.0 mm (35 mm equivalent: 52.0 mm)
Hyperfocal Distance : 15.14 m
Light Value : 11.3
-- press any key --
I cann't tell whether this failure is same as the Mirror Lockup issue in this forums, since my mirror was just locked less than 1 second, and camera reset itself.
Hoping this will help to Pentax to solve it.
Best regards,
