09-18-2014, 09:10 PM   #16
tabl10s's Avatar
QuoteOriginally posted by ruggiex Quote
K3 doesn't seem to be able to dump and write lens firmware last time I tried. I'm not sure if the "editing" function works since I never tried.
The other thing you can do is additional AF adjustment beyond what regular menu give you since *I believe* the regular menu adjustment is in addition to debug menu adjustment.
Also, debug menu was found because of this thread - https://www.pentaxforums.com/forums/6-pentax-dslr-discussion/250555-resurrect...e-hacking.html AFAIK.
Will it allow you to adjust the built-in level if askew?
09-19-2014, 01:59 AM   #17
Tjompen1968's Avatar
I was going to link but forgot. Yes, like that.
---------- Post added 09-19-14 at 11:00 AM ----------
QuoteOriginally posted by tabl10s Quote
No idea. I would leave that to the Pentax workshop.
10-08-2014, 06:42 PM   #18
Yes, you can change the region code to 00, then all the languages will show up.
card, debug, dslr, file, files, k-3, k-3 debug menu, k3, menu, mode, pentax k-3, pentax k-3 debug, sd
Debug menu on KX sbyrne Troubleshooting and Beginner Help 3 06-30-2013 10:23 AM
K-x AF "debug menu" calibration methodology question GibbyTheMole Pentax DSLR Discussion 3 03-01-2012 02:52 PM
K100d Super Debug Menu Instructions rmtschanz Pentax DSLR Discussion 5 04-28-2010 06:16 AM
K10d-debug menu-IR possible? Bokeh Pentax DSLR Discussion 6 05-17-2008 05:54 PM
K100D Super Debug menu joelw135 Pentax DSLR Discussion 9 10-18-2007 04:23 AM
All times are GMT -7. The time now is 11:50 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
