09-16-2014, 07:54 AM - 2 Likes   #1
Unregistered User
Guest
Pentax K-3 Debug Menu FYI
After some surfing the net I finally found what I was looking for;
The K-3 Debug Mode
This is how you enter:
Create 2 files in the root of SD card (Make sure your computer shows the file endings, i.e .txt, .PEF, . JPG etc)
00077760.502
DEVELOP.MOD
Open and add the text [OPEN_DEBUG_MENU] to the first file.
Insert the SD card in slot 1 and turn on the camera without closing the card door.
Enable Debug Mode and press OK. You can now remove the files.
In the Menus, before the C1-menu, you now will find a hidden menu.
What do you need this for? Well, that is up to you and your imagination.
/T
DISCLAMER: YOU DO THIS AT YOUR OWN RISK SO READ ABOUT THIS ON THE INTERNET.
JUST ENTERING THE DEBUG MODE SEEMS HARMLESS THIS FAR AND I HAVE USED IT MANY TIMES TO ADJUST THE AF ON MY OLDER CAMERAS THAT DID NOT HAVE THE FINE TUNING THE K-3 HAS.
THERE ARE MANY SETTING I HAVE NO IDEA WHAT THEY DO...
09-16-2014, 08:02 AM   #2
I'm curious as to the contents of the hidden menu and what one would use the Debug for...
09-16-2014, 08:20 AM   #3
QuoteOriginally posted by nomadkng Quote
This thread is one example of what you can do from the debug menu.
09-16-2014, 08:24 AM   #4
Unregistered User
Guest
You can change the region settings, i.e languages. Well from Swedish region to Singapore region and back. Hopefully your can do the vise virsa...
09-16-2014, 08:36 AM   #5
QuoteOriginally posted by rskura Quote
K3 doesn't seem to be able to dump and write lens firmware last time I tried. I'm not sure if the "editing" function works since I never tried.
The other thing you can do is additional AF adjustment beyond what regular menu give you since *I believe* the regular menu adjustment is in addition to debug menu adjustment.
Also, debug menu was found because of this thread - https://www.pentaxforums.com/forums/6-pentax-dslr-discussion/250555-resurrect...e-hacking.html AFAIK.
09-16-2014, 08:41 AM   #6
QuoteOriginally posted by ruggiex Quote
Interesting . . . . I actually used my K-7 to switch my DA*16-50 to screw drive, because at the time I couldn't find how to access the K-3 debug menu.
09-16-2014, 09:47 AM   #7
Otis Memorial Pentaxian
The various tools that display on boot are intriguing as is the debug menu itself.
Does anyone have any idea what all this stuff does?
09-16-2014, 10:19 AM   #8
Unregistered User
Guest
To someone who does not understand all this programming lingo that thread is somewhat difficult to follow...
I found it on google+.
09-16-2014, 11:03 AM   #9
QuoteOriginally posted by Tjompen1968 Quote
Well if someone wants to actually compile a list of Debug Menu items and their application in an easy to follow, layman's language, it might be helpful.
That way, if anyone sees a particular feature they'd like to utilize, it would be incentive to implement Debug Mode.
As of right now, I'm curious but not inclined to Debug my K3 just to rummage around in the closet.
09-16-2014, 11:47 AM   #10
Which is probably the best reason to proceed with caution. The so-called debug menu's purpose is not for troubleshooting or exposing hidden treasures. It appears to be a toolkit for QA purposes or to "debug" issues of firmware under development, a test harness if you would. There is huge potential to brick a camera.
09-18-2014, 01:23 PM   #11
File Text
Does the necessary text include the brackets?
09-18-2014, 01:48 PM   #12
Unregistered User
Guest
QuoteOriginally posted by rodeknyt Quote
Yes it does. Write or copy:
[OPEN_DEBUG_MENU]
09-18-2014, 01:49 PM   #13
Jonathan Mac's Avatar
I used debug to make minor changes to the AF of my K200D, which doesn't allow this at all in the normal user menu. I see no reason at all to do it for a K3, it's very risky and I don't see what benefit it could bring.
09-18-2014, 01:51 PM   #14
Unregistered User
Guest
QuoteOriginally posted by Jonathan Mac Quote
If you buy your camera in Singapore and bring it to Sweden you might want to be able to choose Swedish menus. Using this hack makes that possible.
09-18-2014, 06:06 PM   #15
You mean like on this thread?
https://www.pentaxforums.com/forums/172-pentax-k-3/265668-international-langu...ngs-k-3-a.html
card, debug, dslr, file, files, k-3, k-3 debug menu, k3, menu, mode, pentax k-3, pentax k-3 debug, sd
Debug menu on KX sbyrne Troubleshooting and Beginner Help 3 06-30-2013 10:23 AM
K-x AF "debug menu" calibration methodology question GibbyTheMole Pentax DSLR Discussion 3 03-01-2012 02:52 PM
K100d Super Debug Menu Instructions rmtschanz Pentax DSLR Discussion 5 04-28-2010 06:16 AM
K10d-debug menu-IR possible? Bokeh Pentax DSLR Discussion 6 05-17-2008 05:54 PM
K100D Super Debug menu joelw135 Pentax DSLR Discussion 9 10-18-2007 04:23 AM
All times are GMT -7. The time now is 04:55 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
