09-27-2014, 08:15 AM   #1
Libor's Avatar
How to set up sooting into RAW only
Does someone know, how to set up DSLR Pentax K-3 into mode, when pictures are saved only into RAW format, no Jpeg. I have tried all the options provided by the producer, either saving 1, paralelly 2 card or continously and always jpeg file were there. Can someone help me with the settings?
I do not need Jpegs any more.
09-27-2014, 08:30 AM   #2
Go to info and you should be able to change the file format
09-27-2014, 08:47 AM   #3
Press the 'menu' button.
Go to the 'Rec Mode' menu (with the little camera icon).
Go to 1 - Image Capture Settings
Select File Format, then select 'RAW - DNG'
09-27-2014, 09:00 AM   #4
Menu's for RAW on the K-3:
09-28-2014, 12:42 AM   #5
Libor's Avatar
Hello to all,
an thanks for advice. unfortunatelly I do already have such a setting on my camera. And it still saves jpeg's alongwith raws. When export to hard drive is done I just delete all the jpeg files and work with raw format. I just wanted to know if there is option just to switch jpeg off.
Anyway thanks again.
Libor
09-28-2014, 12:53 AM   #6
Just select Image Capture Settings > File Format > RAW DNG.
If you choose DNG as your RAW file format, the 3 file format options you have are: JPG, RAW DNG, and RAW+DNG
RAW DNG will save 1 X DNG file.
RAW+DNG will produce 1 X DNG file plus 1 X JPEG file simultaneously.
RAW+DNG seems to be what you have selected. Don't use that.
09-28-2014, 01:53 AM   #7
Tjompen1968's Avatar
Or PEF...
Page 37 in the manual gives you all the different options. A quick way to edit the settings are if you open the menu using the INFO button and in the lower left you have the options for the RAW/JPEG/card selection.
09-29-2014, 04:45 AM   #8
Libor's Avatar
Rawr, thanks to your explanation, I will try it
Libor
dslr, dslr k-3, jpeg, k-3, k3, no jpeg, pentax k-3, raw, settings
How to set up a Pentax Red Dot sight for the Q crewl1 Pentax Q 57 10-09-2014 03:41 PM
How do I set my K5 to shoot RAW Dobson Pentax K-5 8 01-14-2013 08:05 AM
My nice and easy homemade Macro set-up - How to svanvenetien Photographic Technique 25 12-22-2012 11:51 AM
How to save RAW picture into JPEG in a quick way! hiddenshadow Digital Processing, Software, and Printing 6 11-12-2010 11:04 AM
How to get RAW image into Mac Irwin General Talk 3 04-22-2007 06:46 PM
All times are GMT -7. The time now is 11:44 AM. | See also: NikonForums.com, part of our network of photo forums!
